Testdisk is not seeing my newly re-created drive array
DaveDog
#1 Post by DaveDog »
I believe I followed the instructions correctly...
Using the Intel Bios Utility I reset both HDDs to non-member
Re-created the array with the same name/format/member order (RAID1)
Booted from Windows 7 USB installation media
Went to system repair, command prompt and ran TestDisk
The only drives that appear are the USB drive and the windows RAM drive created to run setup
Any ideas for me?
Log file below
Dave
Wed Jun 28 14:47:07 2017
TestDisk 7.1-WIP, Data Recovery Utility, May 2017
Compiler: GCC 5.4, Cygwin 2005.2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=15931539456
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=15931539456
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=15930490880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\X:)=3162112
Disk /dev/sda - 15 GB / 14 GiB - CHS 1936 255 63, sector size=512 - Mass Storage Device, FW:1.00
Drive X: - 3162 KB / 3088 KiB - CHS 193 16 2, sector size=512 - Microsoft Corporation RamDisk
Re: Testdisk is not seeing my newly re-created drive array
It may be a problem of missing driver. If you run Windows Disk Manager, do you see the missing Raid 1 ?
DaveDog
#3 Post by DaveDog »
The OS is on the array, I never have tried to run dskmgmt.msc from the recovery command prompt. Will give that a try.
DaveDog
#4 Post by DaveDog »
Update:
Windows 10 recovery media found the array, so it must have been drivers not on the Win 7 recovery media.
