Recovering HFS+ partition wiped by Windows
plsncld
#1 Post by plsncld »
Running testdisk I can see multiple entries which could be the partition that I wish to recover (350GB HFS+). I've tried to write some of the entries of around the right size and mount them but they won't mount, with errors relating to the filesystem and superblock.
Any suggestions?
Sat Apr 1 11:59:58 2017
OS: Darwin, kernel 16.4.0 (Darwin Kernel Version 16.4.0: Thu Dec 22 22:53:21 PST 2016; root:xnu-3789.4
Compiler: GCC 4.0
Compilation date: 2017-03-16T18:15:19
Disk /dev/disk0 - 251 GB / 233 GiB - 490234752 sectors (RO), sector size=512
Disk /dev/disk2 - 2000 GB / 1862 GiB - 3906928640 sectors, sector size=512
Disk /dev/rdisk0 - 251 GB / 233 GiB - 490234752 sectors (RO), sector size=512
Disk /dev/rdisk1 - 178 GB / 165 GiB - 347657384 sectors (RO), sector size=512
Disk /dev/rdisk2 - 2000 GB / 1862 GiB - 3906928640 sectors, sector size=512
Partition table type: EFI GPT
Analyse Disk /dev/rdisk2 - 2000 GB / 1862 GiB - 3906928640 sectors
Trying alternate GPT
FAT32 at 2048/0/1
FAT1 : 8196-16385
FAT2 : 16386-24575
start_rootdir : 24576 root cluster : 2
Data : 24576-67108863
sectors : 67108864
cluster_size : 64
no_of_cluster : 1048192 (2 - 1048193)
fat_length 8190 calculated 8190
heads/cylinder 255 (FAT) != 1 (HD)
sect/track 63 (FAT) != 1 (HD)
FAT32 at 2048/0/1
FAT: cluster=2(0x2), pos=26624
EFI System 2048 67110911 67108864 [EFI System Partition] [ESD-USB]
FAT32, blocksize=32768, 34 GB / 32 GiB
HFS magic value at 347957696/0/1
part_size 2880
Mac HFS 347957696 347960575 2880 [System Startup]
HFS blocksize=512, 1474 KB / 1440 KiB
HFS magic value at 347963568/0/1
part_size 1600
Mac HFS 347963568 347965167 1600 [MacDrawStartup]
HFS blocksize=512, 819 KB / 800 KiB
NTFS at 349272495/0/1
filesystem size 20948697
mftmirr_lcn 1309293
MS Data 328323799 349272495 20948697
NTFS found using backup sector, blocksize=4096, 10725 MB / 10228 MiB
mftmirr_lcn 1309293
MS Data 349272495 370221191 20948697
NTFS, blocksize=4096, 10725 MB / 10228 MiB
HFS+ magic value at 683109580/0/1
part_size 682699944
Mac HFS 683109580 1365809523 682699944
HFS+ blocksize=4096, 349 GB / 325 GiB
P EFI System 2048 67110911 67108864 [EFI System Partition] [ESD-USB]
P Mac HFS 683109580 1365809523 682699944
gpt_change_part_type
Change partition type:
P HFS+ 683109580 1365809523 682699944
1 P EFI System 2048 67110911 67108864 [EFI System Partition] [ESD-USB]
2 P Mac HFS 683109580 1365809523 682699944
write!
Sat Apr 1 23:05:10 2017
Compiler: GCC 4.0
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=3906928639 (expected 3906928639)
hdr_lba_start=34
hdr_lba_end=3906928606
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 2048/0/1
FAT1 : 8196-16385
FAT2 : 16386-24575
sectors : 67108864
cluster_size : 64
FAT32 at 2048/0/1
part_size 682699944
New geometry
Disk /dev/rdisk2 - 2000 GB / 1862 GiB - CHS 243196 255 63 sector_size=512
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=3906928639 (expected 3906943739)
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
New options :
Dump : No
Align partition: Yes
Expert mode : No
Analyse Disk /dev/rdisk2 - 2000 GB / 1862 GiB - CHS 243196 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
