BSoD immediately after run TestDisk
KIPPIE408
#1 Post by KIPPIE408 »
Symptom: BSoD is shown immediately after run TestDisk, as shown in the title.
Conditions:
Windows 10 version 1703, build 15063.447, 64-bit.
* Checked from winver. Upgraded from Windows 8.1.
TestDisk 7.0 or 7.1-WIP (occurs on both versions).
3.5-inch SATA hard disk to make restored ("Disk A") connected to a SATA port on motherboard directly.
* If Disk A is connected via SATA-to-USB 2.0 connector, no BSoD is shown. But for nine out of ten, deeper search fails because a short disconnection/reconnection comes out.
Log & Messages: BSoD says SYSTEM THREAD EXCEPTION NOT HANDLED, and that failure was from ntfs.sys.
Sat Jul  8 02:21:22 2017
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=499602450944
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2000395805184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1476108746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=524286951424
filewin32_getfilesize(\\.\H:) GetFileSize err 잘못된 기능입니다.
filewin32_setfilepointer(\\.\H:) SetFilePointer err 잘못된 기능입니다.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=500107804672
Disk /dev/sda - 2000 GB / 1863 GiB - CHS 258401 240 63, sector size=512
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Disk /dev/sdd - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Drive C: - 499 GB / 465 GiB - CHS 60739 255 63, sector size=512
Drive D: - 2000 GB / 1863 GiB - CHS 258400 240 63, sector size=512
Drive E: - 1476 GB / 1374 GiB - CHS 179459 255 63, sector size=512
Drive F: - 524 GB / 488 GiB - CHS 63740 255 63, sector size=512
Drive M: - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Re: BSoD immediately after run TestDisk
You can try to boot from a Linux LiveUSB, see https://www.cgsecurity.org/testdisk.pdf and run TestDisk to check if you have the same problem.
If it's an hardware problem, contacting a data recovery company may be the only solution to recover your data...
