Dear All
I got a serious problem with an 1TB external USB 3.0 HDD. When using it to move data from an old computer to a new one, out of a sudden the explorer showed it as a local drive and I haven't any chance to open it and to get access to my data. The windows tool 'Datenträgerverwaltung' (don't know the English term) showed it having the file system Raw.
It tried testdisk 7,0-wip but didn't succeed.
From the log I am picking up the following after having just confirmed the highlighted 'none' for patition table type:
Status: OK
Status: OK
After having started again and proceed with 'intel' type the following is logged:
Bad relative sector.
1 * Sys=72 13577 238 11 119521 238 60 1701990410
2 * Sys=74 45381 70 3 79242 34 29 543974724 search_part()
and
NTFS found using backup sector, blocksize=4096, 1000 GB / 931 GiB
Partition not added.
Does this mean somthing is there and I just didn't use testdisk correctly or would it be better to use version 7.1_wip, is ther any chance to get back my approx 500GB of data
I need some help
Thanks a lot
Jörg
Here the complete log file:
Mon Aug 7 21:23:53 2017
TestDisk 7.0-WIP, Data Recovery Utility, April 2015
OS: Windows XP SP3
Compilation date: 2015-04-16T08:48:23
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=8242855936
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=1000170586112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=8242855936
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=1000170586112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=27291446784
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=117907658240
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=104857600000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=1000169537536
filewin32_getfilesize(\\.\G:) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\G:) SetFilePointer err Unzulässige Funktion.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=8242184192
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512
Disk /dev/sdb - 8242 MB / 7861 MiB - CHS 1002 255 63, sector size=512
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121597 255 63, sector size=512
Drive C: - 27 GB / 25 GiB - CHS 3317 255 63, sector size=512
Drive D: - 117 GB / 109 GiB - CHS 14334 255 63, sector size=512
Drive E: - 104 GB / 97 GiB - CHS 12748 255 63, sector size=512
Drive F: - 1000 GB / 931 GiB - CHS 121597 255 63, sector size=512
Drive M: - 8242 MB / 7860 MiB - CHS 1002 255 63, sector size=512
Partition table type: None
NTFS at 0/0/1
filesystem size 1953456128
mftmirr_lcn 122091007
NTFS at 0/0/1
P NTFS 0 0 1 121597 5 8 1953456128
ntfs_boot_sector
NTFS at 0/0/1
NTFS at 0/0/1
Status: OK
Status: OK
Sectors are identical.
ntfs_mapping_pairs_decompress() failed: Input/output error.
ntfs_mft_load(): Failed.
ntfs_boot_sector
NTFS at 0/0/1
NTFS at 0/0/1
Status: OK
Status: OK
rebuild_NTFS_BS
mft at 976728056
ntfs_find_mft: mft_lcn 786432
ntfs_find_mft: mftmirr_lcn 122091007
New / Current boot sector
filesystem size 1953456128 1953456128
sectors_per_cluster 8 8
mft_lcn 786432 786432
mftmirr_lcn 122091007 122091007
clusters_per_mft_record -10 -10
clusters_per_index_record 1 1
ntfs_boot_sector
NTFS at 0/0/1
NTFS at 0/0/1
Status: OK
Status: OK
_______________________________________________________________________________________________________________
Analyse
Geometry from i386 MBR: head=116 sector=52
BAD_RS LBA=218129509 5918957
check_part_i386 1 type 72: no test
BAD_RS LBA=729050177 1083631
check_part_i386 2 type 74: no test
BAD_RS LBA=168653938 1838434
3 * NetWare 3.11+ 10498 56 41 10498 56 40 0
NTFS at 121597/5/8
HPFS - NTFS 0 0 1 121597 5 8 1953456128
NTFS at 121597/5/8
Analyse
NTFS at 121597/5/8
External HDD with file system Raw
Re: External HDD with file system Raw
Have you try chkdsk ? What is the output ?
Read "Repairing filesystem" from https://www.cgsecurity.org/testdisk.pdf
I didn't try chkdsk, because the disk manager is showing the disk having now the raw file system and as I understood para 7,5 of testdisk.pdf chkdsk is not available for this file system. Shall I try it nevertheless?
Thanks
Jörg
Thanks
Jörg
I did read the instruction and since the disk manager showed the disk as having the file system raw, I only used testdisk.
this what I did
1. I selected 'created'
at the next screen patition table type 'none' has been highlighted by testdisk
2. I selected 'advance'
a the next screen I got:
3. I selected 'boot'
at the next screen I got
status: OK
back up boot sector
status OK
sectors are identical
A valid NTFS Boot sector must be present in order to access any data; even if the partition in not
bootable
3. I selected 'List'
at the next screen I got:
Can't open file system. Filesystem seems damaged
4. I selected 'quit' and then 'rebuild boot BS'
file system size 1953456128 1953456128
sectors per cluster 8 8
Extrapolated boot sector and current boot sector are different
5. I selected 'lst'
Can't open filesystem. Filesystem seems damaged
should I have selected MFT_repair furhter up?
this what I did
status: OK
back up boot sector
status OK
bootable
5. I selected 'lst'
Update
Problem has been solved in the meantime by a colleague. As I have been told Win 10 inbuild tools were sufficient to convert it back from raw into NTFS
