I made a mistake with Disk Utility mac os x
macuser
#1 Post by macuser »
I have a big problem ...
I had external HDD with 2 partitions. I wanted to resize one partition on Disk Utility, When I applied resize it suddenly erased both partitions. What should I do now ? it shows 2 empty partitions ...
Re: I made a mistake with Disk Utility mac os x
You can try TestDisk, Quick Search, Deeper Search. In the list of partitions, search for partitions where you see "+Backup" at the bottom. If the partition size looks ok, set the partition as P(rimary).
On next screen, if you see all your partitions, choose Write, confirm, Quit and restart your computer.
macuser
#3 Post by macuser »
Thank you cgrenier for reply. Which disk should I select "rdisk" or "disk" ?
macuser
#4 Post by macuser »
After I take analyze it shows errors bellow ...
macuser
#5 Post by macuser »
After I click Quick Search I get message:
macuser
#6 Post by macuser »
any info would be appreciated ...
macuser
#7 Post by macuser »
cgrenier wrote: 23 Aug 2017, 08:27 You can try TestDisk, Quick Search, Deeper Search. In the list of partitions, search for partitions where you see "+Backup" at the bottom. If the partition size looks ok, set the partition as P(rimary).
Could I get any help ?
macuser
#8 Post by macuser »
Is it normal that as more deep search is making the longer it takes ? now is running for 8 days and it's only 50% ??? Why admin wont answer me ? maybe your program doesnt recovery files or it's not understanding what is going on and takes much time for searching ? I would like to get the answer...
macuser
#9 Post by macuser »
What I see now it searches 1% / day... and left 50% ... wtf ?
