Reformat a failing microSD card or HDD?
SyncroScales
#1 Post by SyncroScales »
Hi.
I was wondering what can be done when a microSD card or HDD keeps disconnecting from a computer? Testdisk will not recognize the media. It cannot due to the fact the media is just disconnecting. A different USB cord has not helped.
If there are no other options, is it advisable to re-format the media and then use testdisk, photorec or other programs to access what might be left?
How can the format be done? Does a re-format need to be done a certain way for certain types of media?
E.G.: Should a NTFS system be the re-format since the original was? Or should a exFAT system be the re-format since the original was?
Will it make things harder to recover data if a different format is done? E.G.: Originally NTFS then re-formatted to exFAT? Or Originally exFAT and reformatted to ext4 or FAT16?
Would a Quick format and Error Checking be a better option that will not destroy as much of the data compared to a Full format?
Thank you.
