SD card - no partition found
totallybree
#1 Post by totallybree »
Hi there!
I'm trying to a recover an SD card that was in my phone that just suddenly stopped working. When I run testdisk, there's no partition found. I've tried Deeper Scan and got the same. When I tried Advanced, I just see a message that says no partition available. Can anyone help? Here's what I see on the log:
Tue Sep 12 12:47:03 2017
TestDisk 7.1-WIP, Data Recovery Utility, July 2017
OS: Windows 8 (9200)
Compiler: GCC 5.4, Cygwin 2005.2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=63864569856
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=63864569856
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=472385445888
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=25740443648
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=0
Fix disk size using CHS
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - TOSHIBA MQ01ABF050, S/N:842LT00XT, FW:AM0P2C
Disk /dev/sdb - 63 GB / 59 GiB - CHS 7764 255 63, sector size=512 - Realtek PCIE Card Reader, FW:1.00
Disk /dev/sdb - 63 GB / 59 GiB - Realtek PCIE Card Reader
Analyse Disk /dev/sdb - 63 GB / 59 GiB - CHS 7764 255 63
Partition: Read error
file_pread(5,16,buffer,32(0/0/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,48(0/0/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,95(0/1/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,111(0/1/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,158(0/2/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,2080(0/33/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,51(0/0/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,98(0/1/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,119(0/1/57)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,169(0/2/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,2082(0/33/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,63(0/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,79(0/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,126(0/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,142(0/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,189(0/3/1)) ReadFile Data error (cyclic redundancy check).
The log goes on like this forever.
I'd really appreciate any help! Thanks!
Re: SD card - no partition found
CRC errors are hardware errors. You need to contact a data recovery company.
