Cannot recover WD 3TB partition.
radagast
#1 Post by radagast »
Hi all,
I was trying to recover the partition of my external 3TB HDD by using testdisk. Unfortunately it was unsuccessful. I followed the procedure but it shows the same problem again.
Here is my setup:
1. Linux Mint 18.2
2. HDD connected through USB
3. HDD size: 3 TB, 1 NTFS partition
I am posting my screenshots here,
I have restarted the PC and it seems it didn't work.
My log file looks life this,
Sat Sep 23 19:36:29 2017
OS: Linux, kernel 4.10.0-35-generic (#39~16.04.1-Ubuntu SMP Wed Sep 13 09:02:42 UTC 2017) x86_64
Compiler: GCC 5.3
ext2fs lib: 1.42.13, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.0
/dev/sda: size       1953525168 sectors
/dev/sda: user_max   1953525168 sectors
/dev/sda: native_max 1953525168 sectors
/dev/sda: dco        1953525168 sectors
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - TOSHIBA HDWD110, S/N:477H6DSFS, FW:MS2OA8J0
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 45599 255 63, sector size=4096 - WD Elements 107C, FW:1042
Disk /dev/sdb - 3000 GB / 2794 GiB - WD Elements 107C
Analyse Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 45599 255 63
Invalid NTFS or EXFAT boot
 1 * HPFS - NTFS              0  32 33 267349 121 35 4294967295
NTFS at 0/4/5
filesystem size           732558080
sectors_per_cluster       1
mft_lcn                   4
mftmirr_lcn               366279039
clusters_per_mft_record   1
     HPFS - NTFS              0   4  5 45599 165  6  732558080 [3tb]
   * HPFS - NTFS              0   4  5 45599 165  6  732558080 [3tb]
Hint for advanced users. dmsetup may be used if you prefer to avoid to rewrite the partition table for the moment:
echo "0 5860464640 linear /dev/sdb 2048" | dmsetup create test0
 1 * HPFS - NTFS              0   4  5 45599 165  6  732558080 [3tb]
write!
Anyone have any idea what am I missing here?
Re: Cannot recover WD 3TB partition.
Run TestDisk, ANalyse, Quick Search, use 'a' to manually add the partition
Set this partition as *(bootable), the other (if any) as D(eleted).
On next screen, choose Write and confirm.
Now, choose Advanced, you must have
Choose Boot, RebuildBS, List. If you can see your files, choose Write, confirm, Quit
Restart your computer.
radagast
#3 Post by radagast »
Thanks for the reply. I followed the procedure you have suggested and come up with this after clicking rebuild,
The partition listed in your screenshot doesn't match the partition I told you to recover...
