Hi
A Thosiba external hard drive went raw.
I used photorec but cannot recover any pictures.
I cannot attach the log file. I keep getting invalid file extention error message.
here is the log file
Any help is much appreciated.
Sat Sep 23 10:21:25 2017
OS: Linux, kernel 4.10.0-28-generic (#32~16.04.2-Ubuntu SMP Thu Jul 20 10:19:48 UTC 2017) x86_64
Compiler: GCC 5.3
ext2fs lib: 1.42.13, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.0
/dev/sda: LBA, LBA48, DCO support
/dev/sda: size 976773168 sectors
/dev/sda: user_max 976773168 sectors
/dev/sda: dco 976773168 sectors
/dev/sdb: size 976773168 sectors
/dev/sdb: user_max 976773168 sectors
/dev/sdb: native_max 976773168 sectors
/dev/sdb: dco 976773168 sectors
/dev/sr1 is not an ATA disk
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST500DM002-1BD142, S/N:Z6E1XBN7, FW:HP73
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - TOSHIBA MK5076GSX, S/N:81OAP0TNT, FW:GS001A
Disk /dev/sr1 - 616 MB / 588 MiB - 301160 sectors (RO), sector size=2048 - HL-DT-STDVD-RAM GH22NS30, FW:1.01
Disk /dev/sdb - 500 GB / 465 GiB - TOSHIBA MK5076GSX
ntfs_mst_post_read_fixup_warn: magic: 0x4ef7fd0a size: 1024 usa_ofs: 64020 usa_count: 40430: Invalid argument
Record 0 has no FILE magic (0x4ef7fd0a)
NTFS at 60800/254/63
filesystem size 976768001
mft_lcn 2
mftmirr_lcn 48
HPFS - NTFS 0 1 2 60800 254 63 976768001
NTFS found using backup sector, blocksize=4096, 500 GB / 465 GiB
mft_lcn 2
mftmirr_lcn 48
HPFS - NTFS 60800 254 63 121601 253 61 976768001
This partition ends after the disk limits. (start=976768064, size=976768001, end=1953536064, disk end=976773168)
The harddisk (500 GB / 465 GiB) seems too small! (< 1000 GB / 931 GiB)
L HPFS - NTFS 0 1 2 60800 254 63 976768001
Hint for advanced users. dmsetup may be used if you prefer to avoid to rewrite the partition table for the moment:
echo "0 976768001 linear /dev/sdb 64" | dmsetup create test0
Not an exFAT boot sector.
add_ext_part_i386: max
add_ext_part_i386: min
1 E extended LBA 0 1 1 60800 254 63 976768002
5 L HPFS - NTFS 0 1 2 60800 254 63 976768001
mft_lcn 2
mftmirr_lcn 48
mft_lcn 2
mftmirr_lcn 48
Partion is raw cannot recover pictures
Re: Partion is raw cannot recover pictures
Run TestDisk, Analyze, Quick Search, Stop, use 'a' to manually add the following partition
HPFS - NTFS 0 1 1 60800 254 63
Set the partition as *(bootable).
On next screen, choose Write and confirm.
In Advanced, select
1 * HPFS - NTFS 0 1 1 60800 254 63
Boot, RebuildBS, List. If you can see your files, choose Write, confirm, Quit and restart your computer.
In Advanced, select
Thank you for the prompt reply.
I will try and post the results.
Younes
Younes
hi
I have tried the solution you suggested.
Rebuilding the BS failed. So I had an option to use the back up BS. I did.
But i still could not see my the files.
I tried repairing the $mft file. but I could not. I get the terrible message $mft and $mftmirr are bad. Fail to repair.
Any other suggestions?
All my borther's kids pictures are in this drive
Try PhotoRec. It will not recover the original filenames and you will have to sort the files (see https://www.cgsecurity.org/testdisk.pdf) but it's better than nothing.
