AZZ Cardfile
anttestdisk
AZZ Cardfile
#1 Post by anttestdisk »
Thank you for your incredibly useful tools! I don't know what I would have done without theem.
I would like to know whether photorec will recognise an AZZ Cardfile .azz file extension, and if not, how I should add it to the register.
As I do not have a .azz file available (lost it!), I attempted to download a sample file from the AZZ Cardfile website to try it in your test: https://www.cgsecurity.org/photorec/sca ... d5399e3758
Kind regards
Anthony Williams
Re: AZZ Cardfile
PhotoRec recovers your sample file as a .zip. Search in the recovered zip files for the files you are looking for.
You can also try testdisk, Advanced, Undelete.
Please tell us if if you succeed in your data recovery.
