Kingston SE9 G2 64GB USB 3.0 Partition Recovery issue
karko
#1 Post by karko »
I am new to this forum so welcome everyone.
My pendrive has become unavailable for unknown reason. I've followed this instruction as I had just the same symptomes.
http://www.cgsecurity.org/wiki/TestDisk_Step_By_Step
During the process I have successfuly recovered part of the partition. The pendrive is now accesible but I can see only few files.
In windows explorer it displays the following:
It seems that files are there are only 13.9GB is free!
Yet when I access it I see only few files.
This is what testdisk analysis is returning:
And results of quick search:
Can you please advise what I can do?
Thank you!
Re: Kingston SE9 G2 64GB USB 3.0 Partition Recovery issue
Run "cmd" (right click "run as administator") and "chkdsk /f e:".
Windows explorer may hide some files/directory by default: https://support.microsoft.com/en-us/hel ... dden-files
karko
#3 Post by karko »
Thank you for quick reply.
Unfortunately I've tried running chkdsk before and I am getting this:
Windows cannot run disk checking on this volume because it is write protected.
I am not able to take down the "Current Read-Only state: Yes" flag. I have tried diskpart, rmPrepUSB, and registry change. The flag is still there:
Also I did apply change to hidden files visibiity with no luck. I have even applied it for operating system files but there is nothing more appearing.
karko
#4 Post by karko »
By the way - when I run files recovery all the other files are recovering! So it seems that everything is there I just cant access it. I would prefer to access those files instead of running restore operation as many system files (for example from some apps) won't get restored. Hence I am doing what I can to fix the structure without data restoration.
karko
#5 Post by karko »
Any chance for an update please?
Regards, Szymon
karko
#6 Post by karko »
Should I give up? :D
#7 Post by cgrenier »
Try to remove the readonly flag:
<pre>
att vol clear readonly
</pre>
To access the files you have copied, you may to take ownership of the files (ie. https://winaero.com/blog/how-to-take-ow ... indows-10/ )
karko
#8 Post by karko »
Sorry you might have missed that but I have tried many options to remove this att. Unfortunately nothing helps...
I am not able to take down the "Current Read-Only state: Yes" flag. I have tried diskpart, rmPrepUSB, and registry change. The flag is still there...
