3Tb MFT repair and data lost after rebuild boot sector
minanapil13
#1 Post by minanapil13 »
i have data in this HDD but partition cannot open in win 7 64x when i merge the two partition by miniTool partition wizard
1- is 2tb
2- is 794 gb
when its finished the data was merge perfectly in the HDD but its till me Windows prompts "You need to format the disk in drive E: before you can use it. Do you want to format it .
then The volume does not contain a recognized file system. Please make sure that all required file system drivers are loaded and that the volume is not corrupted.
so i opened test disk to recover MFT by this steps
and i made rebuild BS
then the 2nd partiton data lost
plz help i`m freaking out years of working it will disappear
i appreciate your support
and plz step by step guide to recover data and make my partition work again :oops:
Re: 3Tb MFT repair and data lost after rebuild boot sector
What is the result if you run "cmd" (right click "run as administrator") and "chkdsk /f e:" ?
If it doesn't work, it's always possible to use PhotoRec but it will not recover the original filenames of your lost files.
minanapil13
#3 Post by minanapil13 »
i can recover some of it ( the first one partition data ) but i need the other one in there folder is that possible ?
or how to fix this partition with the data that it showed me in minitool ( minaaaaaaa) folder and i can forget about the other one data :roll:
MFT and its mirror are perfectly matched win i finished the rebuilding boot sector
mini tool.jpg (47.89 KiB) Viewed 9142 times
minanapil13
#4 Post by minanapil13 »
continue attachment result for first Message
minanapil13
#5 Post by minanapil13 »
minanapil13
#6 Post by minanapil13 »
#7 Post by cgrenier »
The boot sector is damaged. Can you try TestDisk, Advanced, Boot, List ?
If it works, choose BackupBS and confirm.
If it doesn't, try RebuildBS, List, choos Write and confirm if you can see your files.
minanapil13
#8 Post by minanapil13 »
RebuildBS when i did it before it erased the data in the second partiton i don't want take any risk
for my other data
1-TestDisk, Advanced
2-boot is bad
3- List i have my files already in my drive minaaaaaa folder
4- BackupBS not shown to me before i did RebuildBS
minanapil13
#9 Post by minanapil13 »
if i did RebuildBS my data will be erased or deleted ?
because it did it before
