RAW USB flash drive
jeskai963
RAW USB flash drive
#1 Post by jeskai963 »
I have corrupted RAW USB flash drive that is listed as 0/0 space in computer manager.I tried using TestDisk to repair or retrieve the files but this is what I get while trying.Used PC/Intel settings
It has very important files, please help.
I'm inexperienced with data recovery so please be kind.
Re: RAW USB flash drive
Try Quick Search and if no partition is listed, Deeper Search. If it find your partition, set it as P(rimary) and on next screen, choose Write, confirm, Quit.
If it doesn't work, use PhotoRec.
For more details, feel free to read https://www.cgsecurity.org/testdisk.pdf
Good luck
