File sys repair or partition repair or both ?
loij
#1 Post by loij »
Hi , I'm at a point where I'm not sure what the next right thing to do is.
I googled this line from my output
- The harddisk (500 GB / 465 GiB) seems too small! (< 2372 GB / 2209 GiB)
and was reading up on the issue ; that's what brought me here to your forum. So I was reading in your documentation and now I'm not sure what my next step should be . Without some help I have no idea how to repair the file system or do anything else with the partition but I'm doing a lot of searching etc.
I don't know if it's necessary but I'm attaching images of Gparted also so you can know my present configuration. I'm working out of dev/sdb and Linux Mint 18.1 serena thru my CLI with TestDisk.
I don't know if I should try to repair the file system or "continue " with test disk or, try to recover the partition first .
I don't think I should do anything without some guidance , I might just make things worse.
I am only interested in recovering the files from the linux partitions and repairing and repartitioning the drive to reinstall another linux distro in the future. I would like to remove all remnants of the Fat 16 and the NTFS partition from the drives and the computer. Hope I'm not complicating this too much .
Any help you could provide will be GREATLY appreciated ; thank you very much
I do understand that TestDisk is telling me that these 2 Linux partitions that I want to recover are unrecoverable . In that case I'm not sure , again, what's next in order to repair this partition . Move over to the Partition Recovery documentation and forum I guess.
https://imgur.com/a/bGnrw
Re: File sys repair or partition repair or both ?
Please continue on next screen and post the whole testdisk.log file
loij
#3 Post by loij »
Fri Oct 13 16:26:33 2017
OS: Linux, kernel 4.4.0-53-generic (#74-Ubuntu SMP Fri Dec 2 15:59:10 UTC 2016) x86_64
Compiler: GCC 5.3
ext2fs lib: 1.42.13, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.0
/dev/sda: size 1953525168 sectors
/dev/sda: user_max 1953525168 sectors
/dev/sda: native_max 1953525168 sectors
/dev/sda: dco 1953525168 sectors
/dev/sdb: size 976773168 sectors
/dev/sdb: user_max 976773168 sectors
/dev/sdb: native_max 976773168 sectors
/dev/sdb: dco 976773168 sectors
/dev/sdc: LBA, HPA, LBA48, DCO support
/dev/sdc: size 976773168 sectors
/dev/sdc: user_max 976773168 sectors
/dev/sdc: native_max 976773168 sectors
/dev/sdc: dco 976773168 sectors
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000LM014-1EJ164, S/N:W770D4DG, FW:SM28
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST9500325AS, S/N:S2W0TD5A, FW:0003SDM1
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST3500418AS, S/N:9VMBX52X, FW:CC38
Disk /dev/sdc - 500 GB / 465 GiB - ST3500418AS
Analyse Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63
Inode is corrupt (70): Input/output error
NTFS at 0/32/33
filesystem size 976766976
mftmirr_lcn 2
HPFS - NTFS 0 32 33 60801 15 14 976766976
* HPFS - NTFS 0 32 33 60801 15 14 976766976
Hint for advanced users. dmsetup may be used if you prefer to avoid to rewrite the partition table for the moment:
echo "0 976766976 linear /dev/sdc 2048" | dmsetup create test0
dir_partition inode=5
ntfs_readdir failed for cluster 5: Input/output error
5 dr-xr-xr-x 0 0 0 24-Nov-2016 16:12 .
5 dr-xr-xr-x 0 0 0 24-Nov-2016 16:12 ..
1 * HPFS - NTFS 0 32 33 60801 15 14 976766976
NTFS at 0/32/33
mftmirr_lcn 2
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/1117, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 36620800
recover_EXT2: part_size 292966400
Linux 0 32 33 18236 112 52 292966400
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 149 GB / 139 GiB
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/1117, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/1117, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 25
recover_EXT2: s_block_group_nr=25/1117, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 27
recover_EXT2: "e2fsck -b 884736 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=27/1117, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
BAD_RS LBA=532107680 14135623
FAT16 <32M 33122 43 42 288386 72 6 4100817952
This partition ends after the disk limits. (start=532107680, size=4100817952, end=4632925631, disk end=976773168)
recover_EXT2: s_block_group_nr=0/2756, s_mnt_count=63/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 90331904
recover_EXT2: part_size 722655232
Linux 37571 134 4 82554 187 1 722655232
ext4 blocksize=4096 Large_file Sparse_SB Recover, 369 GB / 344 GiB
This partition ends after the disk limits. (start=603586560, size=722655232, end=1326241791, disk end=976773168)
Linux 37571 199 5 82554 252 2 722655232
This partition ends after the disk limits. (start=603590656, size=722655232, end=1326245887, disk end=976773168)
block_group_nr 2187
recover_EXT2: "e2fsck -b 71663616 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=2187/2890, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 94726656
recover_EXT2: part_size 757813248
Linux 13130 37 28 60301 214 9 757813248
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 388 GB / 361 GiB
block_group_nr 2187
recover_EXT2: s_block_group_nr=2187/2756, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 15088 134 23 60071 187 20 722655232
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 369 GB / 344 GiB
block_group_nr 2401
recover_EXT2: "e2fsck -b 78675968 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=2401/2890, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 13143 70 48 60314 247 29 757813248
block_group_nr 2401
recover_EXT2: s_block_group_nr=2401/2756, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 2187
recover_EXT2: s_block_group_nr=2187/2384, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 78125056
recover_EXT2: part_size 625000448
Linux 21154 64 31 60058 186 32 625000448
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 320 GB / 298 GiB
NTFS at 60799/254/63
filesystem size 976751937
mftmirr_lcn 2
HPFS - NTFS 0 1 1 60799 254 63 976751937
NTFS found using backup sector, blocksize=4096, 500 GB / 465 GiB
mftmirr_lcn 2
NTFS: Can't read MFT
HPFS - NTFS 60799 254 63 121599 253 62 976751937
This partition ends after the disk limits. (start=976751999, size=976751937, end=1953503935, disk end=976773168)
NTFS at 60801/15/14
mftmirr_lcn 2
echo "0 976751937 linear /dev/sdc 63" | dmsetup create test0
echo "0 292966400 linear /dev/sdc 2048" | dmsetup create test1
echo "0 976766976 linear /dev/sdc 2048" | dmsetup create test2
echo "0 757813248 linear /dev/sdc 210935808" | dmsetup create test3
echo "0 757813248 linear /dev/sdc 211146752" | dmsetup create test4
echo "0 722655232 linear /dev/sdc 242397184" | dmsetup create test5
echo "0 625000448 linear /dev/sdc 339843072" | dmsetup create test6
dir_partition inode=2
ext2fs_dir_iterate failed with error 1.
Store new MBR code
New options :
Dump : No
Align partition: Yes
Expert mode : No
Partition table type: None
P Unknown 0 0 1 60801 80 63 976773168
Change partition type:
NTFS at 0/32/33
mftmirr_lcn 2
NTFS part_offset=1048576, part_size=500104691712, sector_size=512
NTFS at 0/32/33
mftmirr_lcn 2
P NTFS 0 32 33 60801 15 14 976766976
Write isn't available because the partition table type "None" has been selected.
Disk /dev/sda - 1000 GB / 931 GiB - ST1000LM014-1EJ164
1 P Linux 0 32 33 60800 205 13 976762880
ext4 blocksize=4096 Large_file Sparse_SB, 500 GB / 465 GiB
2 * Linux 60800 205 14 121601 57 56 976758784
2 drwxr-xr-x 0 0 4096 10-Oct-2017 20:34 .
2 drwxr-xr-x 0 0 4096 10-Oct-2017 20:34 ..
11 drwx------ 0 0 16384 10-Oct-2017 20:34 lost+found
2 drwxr-xr-x 0 0 4096 10-Oct-2017 20:37 .
2 drwxr-xr-x 0 0 4096 10-Oct-2017 20:37 ..
11 drwx------ 0 0 16384 10-Oct-2017 20:37 lost+found
TestDisk exited normally
I did continue with TestDisk and explored the linux drives and was told that they are unrecoverable. If it is worth trying some other method from among the tools I will gladly attempt it with some help. I just need to know what to do from here in any case ; whether it be to try undeleting or just repairing and repartitioning . This is a good experience because I have another drive to work on after this .
thanks for your response
