Windows 10 Drive shows as RAW
swin12
#1 Post by swin12 »
Laptop behavior:
When I try to boot, the Windows logo appears and blue screens shortly after citing: unmountable boot device
I have booted to a copy of Mini-Windows 10, where I am trying to run TestDisk. From mini-windows I can see the state of the disk as follows:
Current view of disk:
Disk Management:
Diskpart:
Volume 1 (D: Drive) is the volume I am trying to recover. As you can see, it is not listed as a disk (I'm assuming this is because diskpart can't work with RAW disks).
I take this as a Filesystem repair problem, as the file system type shows as RAW. Now, because of this... I don't seem to be able to use any Windows-based repair tools (I have attempted chkdsk, bootrec and automated windows repair, but with no luck).
TestDisk configuration:
TestDisk so far has gone as follows:
1. Launch TestDisk 7.1 as administrator and select drive D: as the media.
2. Partition type that TestDisk defaults to is None, so I select it.
3. I am brought to a screen showing a single partition labelled "P Unknown" spanning all disk sectors. From here I am offered "Type" "Image Creation" or "Quit". If I select NTFS as type it doesn't seem to make a difference, so I choose Quit.
4. From here I choose analyse and let the scan run for ~8 hours before getting no results.
5. I then run a deeper scan and also get no results.
NOTE: During the scans I can see "Read error at X/Y/Z (lba=####)" for every sector.
Requirements:
I hope to be able to recover files from the disk. To be able to boot to the disk would be a luxury. If I can recover the files, I will likely format the disk clear afterwards.
Any help is appreciated.
Re: Windows 10 Drive shows as RAW
Usually read error means there are bad sectors.
What is the result if you run "cmd" (right click run as administrator) and "chkdsk /f d: ?
swin12
#3 Post by swin12 »
The type of file system is RAW
CHKDSK is not available for RAW drives.
Run TestDisk, select PhysicalDrive1, Advanced, select the partition corresponding to D:, Boot, RebuildBS, List.
If you can see your files, choose Write, confirm, Quit and restart your computer.
Otherwise if you still have error messages, you should clone your disk using ddrescue to a new empty disk as described in https://www.cgsecurity.org/testdisk.pdf
Good luck
swin12
#5 Post by swin12 »
Selecting Drive:
Deafult Partition Type = None:
Forced to select partition type because it is unknown (I choose NTFS):
Rebuild BS Result:
If I quit from this result and attempt to List files, I get: "Can't open filesystem. Filesystem seems damaged"
#6 Post by cgrenier »
diskpart shows volume that doesn't hold in the disks.
Can you boot from a Linux LiveUSB ? (see https://www.cgsecurity.org/testdisk.pdf)
Run the Linux version of testdisk and copy/paste the testdisk.log file.
swin12
#7 Post by swin12 »
Here are the media selection options given (Fedora liveUSB). I do not see the disk or drive (should be ~256GB).
#8 Post by cgrenier »
It's the same problem than from Windows.
Is there a disk not listed or listed with the wrong capacity ?
If a disk has the wrong capacity, try
hdparm --dco-restore /dev/sdb
swin12
#9 Post by swin12 »
Assuming I can rule out:
- /dev/mapper/x
- /dev/dm-x
- /dev/loopx
This leaves me with
- /dev/sda (I know this to be the 2nd physical disk in the laptop, showing correct size)
- /dev/sdb (this is the bootable Fedora media)
I would certainly say that the disk is not being listed. There is definitely something there though, else I wouldn't be able to see the partitions of that disk as shown in my original screenshots (from mini-windows disk management).
Any ideas why a disk might not be showing?
