seagate backup plus desktop drive 6TB become 3.86GB no data
deviance
#1 Post by deviance »
suddenly my 6TB harddisk become corrupt and the geometry also change, i've already update the driver in device manager, nothing has change.
i've been thinking of changing my harddisk geometry to this below data i've gather from seagate's site below:
https://www.seagate.com/www-content/pro ... 57960a.pdf
https://www.seagate.com/www-content/pro ... 05918d.pdf
i've also already try using easeus and gparted to read that disk, but i've got zero result (corrupt/error)
my harddisk is this:
https://www.amazon.com/Seagate-Backup-D ... B00R1P2WDK
Re: seagate backup plus desktop drive 6TB become 3.86GB no data
You should try a dco (Device Configuration Overlay) restore and an hpa (Host Protected Area) restore.
Use hdparm from a Linux LiveUSB, see https://www.cgsecurity.org/testdisk.pdf :
hdparm --dco-restore /dev/sdc
hdparm -N /dev/sdc
hdparm -N XXXX /dev/sdc
deviance
#3 Post by deviance »
I've try what you've suggested , here is the result:
eriol@ubuntu:~$ sudo hdparm -Tt /dev/sdb
[sudo] password for eriol:
/dev/sdb:
read() failed: Input/output error
 Timing buffered disk reads: read() failed: Input/output error
eriol@ubuntu:~$ sudo hdparm --yes-i-know-what-i-am-doing --dco-restore /dev/sdb
/dev/sdb:
 issuing DCO restore command
 HDIO_DRIVE_CMD(dco_restore) failed: Input/output error
 eriol@ubuntu:~$ sudo hdparm -N /dev/sdb
/dev/sdb:
 READ_NATIVE_MAX_ADDRESS_EXT failed: Input/output error
/dev/sdb:
eriol@ubuntu:~$ sudo hdparm -N XXXX /dev/sdb
XXXX: No such file or directory
/dev/sdb:
when I want to check the harddisk using Gparted, this notification show up
and i ignored it
the notification repeat show up about 4-5 times, and the result in gparted is like this
the result after i try fsck
root@ubuntu:~# fsck -a /dev/sdb
fsck from util-linux 2.20.1
fsck.ext2: Attempt to read block from filesystem resulted in short read while trying to open /dev/sdb
Could this be a zero-length partition?
root@ubuntu:~# fsck -y /dev/sdb
e2fsck 1.42.9 (4-Feb-2014)
the result of hdparm -I
eriol@ubuntu:~$ sudo hdparm -I /dev/sdb
/dev/sdb:
ATA device, with non-removable media
	Model Number:       ST6000AS0002
	Serial Number:      Z8401JTS
	Firmware Revision:  AR13
	Transport:          Serial, SATA Rev 3.0
Standards:
	Used: unknown (minor revision code 0x0029)
	Supported: 8 7 6 5
	Likely used: 8
Configuration:
	Logical		max	current
	cylinders	16383	16383
	heads		16	16
	sectors/track	63	63
	CHS current addressable sectors:   16514064
	LBA    user addressable sectors:  268435455
	LBA48  user addressable sectors:    8089950
	Logical/Physical Sector size:           512 bytes
	device size with M = 1024*1024:        3950 MBytes
	device size with M = 1000*1000:        4142 MBytes (4 GB)
	cache/buffer size  = unknown
	Nominal Media Rotation Rate: 7200
Capabilities:
	LBA, IORDY(can be disabled)
	Queue depth: 32
	Standby timer values: spec'd by Standard, no device specific minimum
	R/W multiple sector transfer: Max = 16	Current = 16
	Recommended acoustic management value: 254, current value: 0
	DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
	     Cycle time: min=120ns recommended=120ns
	PIO: pio0 pio1 pio2 pio3 pio4
	     Cycle time: no flow control=120ns  IORDY flow control=120ns
Commands/features:
	Enabled	Supported:
	   *	SMART feature set
	    	Security Mode feature set
	   *	Power Management feature set
	   *	Write cache
	   *	Look-ahead
	   *	Host Protected Area feature set
	   *	WRITE_BUFFER command
	   *	READ_BUFFER command
	   *	DOWNLOAD_MICROCODE
	    	SET_MAX security extension
	   *	48-bit Address feature set
	   *	Device Configuration Overlay feature set
	   *	Mandatory FLUSH_CACHE
	   *	FLUSH_CACHE_EXT
	   *	SMART error logging
	   *	SMART self-test
	   *	General Purpose Logging feature set
	   *	WRITE_{DMA|MULTIPLE}_FUA_EXT
	   *	64-bit World wide name
	    	Write-Read-Verify feature set
	   *	WRITE_UNCORRECTABLE_EXT command
	   *	{READ,WRITE}_DMA_EXT_GPL commands
	   *	Segmented DOWNLOAD_MICROCODE
	    	unknown 119[6]
	   *	unknown 119[7]
	   *	Gen1 signaling speed (1.5Gb/s)
	   *	Gen2 signaling speed (3.0Gb/s)
	   *	Gen3 signaling speed (6.0Gb/s)
	   *	Native Command Queueing (NCQ)
	   *	Phy event counters
	   *	READ_LOG_DMA_EXT equivalent to READ_LOG_EXT
	    	Device-initiated interface power management
	    	Software settings preservation
	   *	SMART Command Transport (SCT) feature set
	   *	SCT Write Same (AC2)
	   *	SCT Error Recovery Control (AC3)
	   *	SCT Features Control (AC4)
	   *	SCT Data Tables (AC5)
	    	unknown 206[7]
	    	unknown 206[12] (vendor specific)
Security:
	Master password revision code = 65534
		supported
	not	enabled
	not	locked
	not	frozen
	not	expired: security count
		supported: enhanced erase
	210min for SECURITY ERASE UNIT. 210min for ENHANCED SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: 5000c5007a552b94
	NAA		: 5
	IEEE OUI	: 000c50
	Unique ID	: 07a552b94
Integrity word not set (found 0x0000, expected 0x34a5)
also already try to initialize GPT partition the hard disk, but also no result
deviance
#4 Post by deviance »
in "Disks" ubuntu 14.04 it has 2 partition, here is the screenshot:
#5 Post by cgrenier »
Looks like you have to use your warranty to get a new disk...
If you need to recover some data, you will have to contact a data recovery company.
deviance
#6 Post by deviance »
cgrenier wrote: 23 Nov 2017, 06:50 Looks like you have to use your warranty to get a new disk...
thanks for the advice :)
sadly i bought the external hard disk at 2012, been damage 3 times.
during 3 years warranty period, 9 months in the clinic, i'm practically really used it for 2y3m :(
now i'm wondering does torrent software can really damage hard disk by insert new file the already full capacity hard disk :roll:
after all i try to format the harddisk to GPT and fail again
