Hi.
A WD external HD of 1 TB (MDL: wd10000H1Q-00) was filled up with data of 400 GB, so I wanted to split the HD into two parts, creating a new mac os extended partition for the apple time machine of my Macbook. It was unplugged during the process, so the whole disk now is uninitialised (but just one, not two, partitions). When running the analysis of testdisk, it imidiately finds this one drive as a Mac partition.
I want my data back, so I guess that I would need to transform it back to the old file system? I dont care for the structure of the disk, so I am ok with exporting the data and setting the disk to zero, but of course the case would be easy.
1) I dont know which the default file system was. (" Most WD Drives come formatted in the NTFS (Windows) or HFS+ (Mac) format.", says WD)
2) I dont remember if I changed this default years ago.
3) I would not know how to do a filesystem change in textdisk.
4) I dont know what the steps to export data (e.g. with PhotoRec) would be.
I am grateful for any instructions or guidance.
Here is the log:
Tue Nov 07 19:21:42 2017
OS: Windows 8 (9200)
Compiler: GCC 4.9, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=105841670144
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=142682882048
Disk \\.\PhysicalDrive0 - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Drive C: - 105 GB / 98 GiB - CHS 12867 255 63, sector size=512
Drive D: - 142 GB / 132 GiB - CHS 17346 255 63, sector size=512
Partition table type (auto): Mac
Partition table type: Mac
Analyse Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63
check_part_mac failed for partition type AF
Bad MAC partition, invalid block0 signature
1 P partition_map 1 63 63
2 P HFS 64 262207 262144
3 P HFS 262208 1953525151 1953262944
4 P Free 1953525152 1953525167 16
NTFS at 70608/40/25
filesystem size 1134320002
mftmirr_lcn 122095000
Unknown 1134320064 2268640065 1134320002
NTFS, blocksize=4096, 580 GB / 540 GiB
Partition not added.
HFS+ magic value at 70608/65/50
part_size 819200000
HFS 1134321664 1953521663 819200000
HFS+ blocksize=4096 + Backup, 419 GB / 390 GiB
file_win32_pread(220,3,buffer,1953525166(121601/80/62)) read err: read after end of file
file_win32_pread(220,8,buffer,1953525167(121601/80/63)) read err: read after end of file
P HFS 1134321664 1953521663 819200000
Support for this filesystem hasn't been implemented.
Thu Nov 09 09:13:48 2017
external HD split into 2 partitions (win + mac) gone wrong - now windows partition missing
Re: external HD split into 2 partitions (win + mac) gone wrong - now windows partition missing
You need to post the results of Quick search AND Deeper Search.
Please quit the application properly to get a full log file.
I did so. it took several days. After deeper search, I quit the program. Strangely the logfile has the same "date last changed" when I started the procedure. This is its content:
Tue Nov 28 11:44:38 2017
NTFS at 70608/40/25
part_size 819200000
file_win32_pread(208,3,buffer,1953525166(121601/80/62)) read err: read after end of file
file_win32_pread(208,8,buffer,1953525167(121601/80/63)) read err: read after end of file
NTFS at 0/1/1
NTFS part_offset=32256, part_size=580771841024, sector_size=512
NTFS at 70608/40/25
part_size 819200000
file_win32_pread(208,8,buffer,1953525161(121601/80/57)) read err: read after end of file
NTFS at 70608/40/25
part_size 819200000
NTFS at 0/1/1
NTFS at 70608/40/25
part_size 819200000
I found a newer log file which was saved somewhere else (strangely):
NTFS at 70608/40/25
part_size 819200000
NTFS at 0/1/1
NTFS at 70608/40/25
part_size 819200000
NTFS at 70608/40/25
part_size 819200000
NTFS at 0/1/1
NTFS at 70608/40/25
part_size 819200000
