partition can't be recovered / partition ends after disk limits
ranteso69
#1 Post by ranteso69 »
I'm trying to fix an USB flash drive (ADATA C906/16GB), that I have unplugged it while it was still operating, and now appears as RAW in Windows Disk Management.
I ran TestDisk on it with no luck. After a quick and depper searches, It finds the partition I'm looking for, but I get the following errors:
Disk /dev/sdg - 15 GB / 14 GiB - CHS 1886 255 63
The harddisk (15 GB / 14 GiB) seems too small! (< 26 GB / 24 GiB)
FAT32 LBA 1336 35 44 3222 221 7 30310272 [NO NAME]
and
This partition ends after the disk limits. (start=21465088, size=30310272, end=51775359, disk end=30310528)
Here are the results of the logfile:
Wed Nov 8 17:17:58 2017
TestDisk 7.1-WIP, Data Recovery Utility, October 2017
OS: Windows XP SP3
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=160041885696
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdg)=15518990336
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=160041885696
filewin32_getfilesize(\\.\PhysicalDrive2) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\PhysicalDrive2) SetFilePointer err Función incorrecta.
filewin32_getfilesize(\\.\PhysicalDrive3) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\PhysicalDrive3) SetFilePointer err Función incorrecta.
filewin32_getfilesize(\\.\PhysicalDrive4) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\PhysicalDrive4) SetFilePointer err Función incorrecta.
filewin32_getfilesize(\\.\PhysicalDrive5) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\PhysicalDrive5) SetFilePointer err Función incorrecta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=15518990336
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=160031015424
filewin32_getfilesize(\\.\D:) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\D:) SetFilePointer err Función incorrecta.
filewin32_getfilesize(\\.\F:) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\F:) SetFilePointer err Función incorrecta.
filewin32_getfilesize(\\.\G:) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\G:) SetFilePointer err Función incorrecta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=320062063104
filewin32_getfilesize(\\.\I:) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\I:) SetFilePointer err Función incorrecta.
filewin32_getfilesize(\\.\J:) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\J:) SetFilePointer err Función incorrecta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=15518990336
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - WDC WD3200AAKX-001CA0, FW:15.01H15
Disk /dev/sdb - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - WDC WD1600JD-22HBC0, FW:08.02D08
Disk /dev/sdg - 15 GB / 14 GiB - CHS 1886 255 63, sector size=512 - ADATA USB Flash Drive, FW:1.00
Disk /dev/sdg - 15 GB / 14 GiB - ADATA USB Flash Drive
Analyse Disk /dev/sdg - 15 GB / 14 GiB - CHS 1886 255 63
FAT32 at 1336/35/44
FAT1 : 36-14821
FAT2 : 14822-29607
start_rootdir : 29608 root cluster : 2
Data : 29608-30310263
sectors : 30310272
cluster_size : 16
no_of_cluster : 1892541 (2 - 1892542)
fat_length 14786 calculated 14786
FAT differs, FAT sectors=0-16/14786
FAT32 at 1336/35/44
FAT: cluster=2(0x2), pos=21494696
FAT32, blocksize=8192, 15 GB / 14 GiB
file_pread(6,11,buffer,30310525(1886/189/29)) ReadFile La unidad no puede hallar el sector requerido.
file_pread(6,1,buffer,30310528(1886/189/32)) ReadFile La unidad no puede hallar el sector requerido.
file_pread(6,2,buffer,30312447(1886/219/61)) lseek err Invalid argument
file_pread(6,8,buffer,30310529(1886/189/33)) lseek err Invalid argument
file_pread(6,1,buffer,30312449(1886/219/63)) lseek err Invalid argument
file_pread(6,14,buffer,30312450(1886/220/1)) lseek err Invalid argument
file_pread(6,3,buffer,30312464(1886/220/15)) lseek err Invalid argument
file_pread(6,3,buffer,30312511(1886/220/62)) lseek err Invalid argument
file_pread(6,8,buffer,30312527(1886/221/15)) lseek err Invalid argument
file_pread(6,11,buffer,30312574(1886/221/62)) lseek err Invalid argument
file_pread(6,2,buffer,30314496(1886/252/31)) lseek err Invalid argument
FAT32 at 1336/35/44
FAT1 : 36-14821
FAT2 : 14822-29607
sectors : 30310272
cluster_size : 16
FAT32 at 1336/35/44
Store new MBR code
Any help will be appreciated.
Javier.
Re: partition can't be recovered / partition ends after disk limits
I don't think this FAT32 boot sector was defined by one of your partition, it's too far from the beginning of the disk.
Try PhotoRec to recover your data.
