TestDisk Freezing, Analyse cylinder at 60801/60800: 99%
sagefox601
#1 Post by sagefox601 »
Very recently I deleted (almost) everything off of an SDD that I was using as an external drive not realizing that I hadn't backed up the most up-to-date versions of a handful of important documents (docx files). Undelete was only able to pull up the last 10 gigs of data or so that were deleted, none of which was what I needed. Photorec was able to get almost all the picture, video, and pdf files but all the document files were corrupted. When attempting to run TestDisk>analyse>quick search, the progress almost immediately jumps from 00% to 99% and freezes. Any help or suggestions on getting past this problem or in general getting my data back would be greatly appreciated!
Imgur album of what I'm doing: https://imgur.com/a/cJrV4
testdisk.log file:
Fri Nov 10 20:39:43 2017
TestDisk 7.1-WIP, Data Recovery Utility, October 2017
OS: Windows 8 (9200)
Compiler: GCC 5.4, Cygwin 2005.2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=249464619008
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000068874240
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=524288000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=119507255296
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\O:)=499971522560
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung SSD 850 EVO 250GB, S/N:S21NNSAG812036J, FW:EMT01B6Q
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZEX-00BN5A0, S/N:WD-WCC3F2PX23AN, FW:01.01A01
Disk /dev/sdc - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - Samsung SSD 850 EVO 120GB, S/N:S21WNX0H402176W, FW:EMT02B6Q
Disk /dev/sdd - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - stockplop, S/N:C31987654321
Disk /dev/sdd - 500 GB / 465 GiB - stockplop
Partition table type: EFI GPT
Analyse Disk /dev/sdd - 500 GB / 465 GiB - CHS 60801 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=976773167 (expected 976773167)
hdr_lba_start=34
hdr_lba_end=976773134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Reserved                   34     262177     262144 [Microsoft reserved partition]
 2 P MS Data                   264192  976771071  976506880 [Basic data partition] [Reserve]
Re: TestDisk Freezing, Analyse cylinder at 60801/60800: 99%
Searching the partitions (Analyse, Quick Search...) is useless in your case. Your partition is not deleted, your files are.
Can you confirm that all docx you have recovered using PhotoRec are corrupted ? I found it very strange.
sagefox601
#3 Post by sagefox601 »
They definitely are, most are only 1 or 2 pages of nothing or gibberish. I'm not sure if this would affect the ability of photorec to recover the documents, but they were set up with numerous text boxes and images. Also, while there were only ~15 documents total, photorec retrieved easily 50 or 60 documents.
Do you get better results if only zip file family are selected in FileOpts ?
