Does this mean my hdd cannot be recover?
beatie
#1 Post by beatie »
I have tried the steps that was listed in other post with "Run TestDisk, Advanced, Boot, RebuildBS, List. If you can see your files, Write, confirm, Quit and restart your computer." But after I tried with RebuildBS > List, nothing come out other than "Can't open filesystem.
Filesystem seems damaged." Is there anything I can do to recover my external hdd? I have attached the testdisk.log below.
Thanks for your help!
Wed Nov 22 11:09:06 2017
TestDisk 7.1-WIP, Data Recovery Utility, October 2017
Compiler: GCC 5.4, Cygwin 2005.2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=240057409536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=15472787456
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=15472787456
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=111332556800
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=111332556800
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=2000363192320
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=732972449792
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=15468593152
Disk /dev/sda - 240 GB / 223 GiB - CHS 29185 255 63, sector size=512 - SATA SSD, S/N:09357076B08050706116, FW:SAFM
Disk /dev/sdb - 15 GB / 14 GiB - CHS 1881 255 63, sector size=512 - Realtek PCIE Card Reader, FW:1.00
Disk /dev/sdc - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512 - WD My Passport 25E2, S/N:WXN1E66FSXN8, FW:4004
Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Fujitsu HDD, S/N:2015112120223, FW:2023
Disk /dev/sde - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - StoreJet Transcend, S/N:YV5E2SW6
Disk /dev/sdd - 2000 GB / 1863 GiB - Fujitsu HDD
Analyse Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 243201 255 63
NTFS at 0/32/33
1 * HPFS - NTFS 0 32 33 243201 45 44 3907024896
NTFS at 0/32/33
filesystem size 3907024896
mftmirr_lcn 2
file_pread(7,2,buffer,3907031039(243201/110/45)) lseek err Invalid argument
file_pread(7,1,buffer,3907031039(243201/110/45)) lseek err Invalid argument
file_pread(7,2,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(7,8,buffer,3907029248(243201/82/18)) lseek err Invalid argument
file_pread(7,8,buffer,3907029376(243201/84/20)) lseek err Invalid argument
file_pread(7,8,buffer,3907029504(243201/86/22)) lseek err Invalid argument
file_pread(7,8,buffer,3907029632(243201/88/24)) lseek err Invalid argument
file_pread(7,8,buffer,3907029760(243201/90/26)) lseek err Invalid argument
file_pread(7,8,buffer,3907029888(243201/92/28)) lseek err Invalid argument
file_pread(7,8,buffer,3907030016(243201/94/30)) lseek err Invalid argument
file_pread(7,8,buffer,3907030144(243201/96/32)) lseek err Invalid argument
file_pread(7,8,buffer,3907030272(243201/98/34)) lseek err Invalid argument
file_pread(7,8,buffer,3907030400(243201/100/36)) lseek err Invalid argument
file_pread(7,8,buffer,3907030528(243201/102/38)) lseek err Invalid argument
file_pread(7,8,buffer,3907030656(243201/104/40)) lseek err Invalid argument
file_pread(7,8,buffer,3907030784(243201/106/42)) lseek err Invalid argument
file_pread(7,8,buffer,3907030912(243201/108/44)) lseek err Invalid argument
file_pread(7,6,buffer,3907031042(243201/110/48)) lseek err Invalid argument
file_pread(7,8,buffer,3907031048(243201/110/54)) lseek err Invalid argument
file_pread(7,3,buffer,3907031056(243201/110/62)) lseek err Invalid argument
file_pread(7,3,buffer,3907031103(243201/111/46)) lseek err Invalid argument
file_pread(7,8,buffer,3907031119(243201/111/62)) lseek err Invalid argument
file_pread(7,11,buffer,3907031166(243201/112/46)) lseek err Invalid argument
file_pread(7,2,buffer,3907033088(243201/143/15)) lseek err Invalid argument
write!
New options :
Dump : No
Align partition: Yes
Expert mode : No
NTFS at 0/32/33
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Status: OK
Status: OK
Sectors are identical.
rebuild_NTFS_BS
mft at 657246432
read_mft_info failed
ntfs_find_mft: sectors_per_cluster invalid
ntfs_find_mft: mft_lcn 786432
ntfs_find_mft: mftmirr_lcn 2
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Status: OK
Status: OK
$MFT has invalid magic.
ntfs_mft_load(): Failed.
Not an exFAT boot sector.
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Status: OK
Status: OK
rebuild_NTFS_BS
Search mft stopped: 327680/3907024896
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Status: OK
Status: OK
repair_MFT
NTFS at 0/32/33
MFT and MFT mirror match perfectly.
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Status: OK
Status: OK
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Wed Nov 22 22:36:27 2017
NTFS at 0/32/33
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Status: OK
Status: OK
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Wed Nov 22 22:47:44 2017
NTFS at 0/32/33
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Status: OK
Status: OK
repair_MFT
NTFS at 0/32/33
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Status: OK
Status: OK
Re: Does this mean my hdd cannot be recover?
Run "cmd" (right click Run As Administrator) and "chkdsk /f d:" (replace d: by the correct drive letter).
If it doesn't work, try PhotoRec to recover your data.
Good luck
