4TB external HDD / Win7 problem
Triangle
#1 Post by Triangle »
Hi together,
I started once my computer, windows 7 saying my 4TB external HDD needs to be formatted. I think this came due to a power supply loss, but who knows...
The HDD contains one huge file container.
I'm currently running deeper search at 90% and attached the editor screenshot.
I could upload the logfile saying no valid file format so I attached it here:
Do you have any recommendations what to do next? From reading similar problems I'd try to change the geometry heads to 255 but I'm not sure if it's the only thing to do.
Wed Nov 15 18:46:45 2017
Compiler: GCC 4.9, MinGW 3.11
ext2fs lib: none, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20120504, curses lib: pdcurses build  3401
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=4000787030016
filewin32_getfilesize(\\.\PhysicalDrive3) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\PhysicalDrive3) SetFilePointer err Unzulässige Funktion.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=127928369152
Disk \\.\PhysicalDrive0 - 128 GB / 119 GiB - CHS 248085 16 63, sector size=512
Disk \\.\PhysicalDrive1 - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512
Drive C: - 127 GB / 119 GiB - CHS 247877 16 63, sector size=512
Partition table type: EFI GPT
Analyse Disk \\.\PhysicalDrive1 - 4000 GB / 3726 GiB - CHS 486401 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=7814037167 (expected 7814037167)
hdr_lba_start=34
hdr_lba_end=7814037134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Reserved                   34     262177     262144 [Microsoft reserved partition]
     Unknown                344246685 3529817888 3185571204
     FATX, 1631 GB / 1518 GiB
Partition not added.
     Unknown                863383117 11681212396875340 11681211533492224
     WBFS, 5980780 TB / 5439488 TiB
LVM magic value at 69782/36/9
SYSV4 Marker at 89100/248/14
recover_sysv4
     Unknown               1431407137 178054139168 176622732032 [ÿš&þ²C]
     SysV4, 90 TB / 82 TiB
     Unknown               3327123377 29404517666643888 29404514339520512
     WBFS, 15055111 TB / 13692544 TiB
NTFS at 219051/219/48
filesystem size           7813771264
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS part_offset=1801762897408, part_size=4000650887168, sector_size=512
mftmirr_lcn               2
     MS Data               3519068159 11332839422 7813771264
     NTFS, blocksize=4096, 4000 GB / 3725 GiB
This partition ends after the disk limits. (start=3519068159, size=7813771264, end=11332839422, disk end=7814037168)
     Unknown               3812793669 11681215346285892 11681211533492224
NTFS at 285524/23/3
mftmirr_lcn               2
NTFS part_offset=2348515589632, part_size=4000650887168, sector_size=512
NTFS at 285524/23/3
mftmirr_lcn               2
     MS Data               4586944511 12400715774 7813771264
This partition ends after the disk limits. (start=4586944511, size=7813771264, end=12400715774, disk end=7814037168)
     Unknown               5137119262 26740127924631581 26740122787512320
     WBFS, 13690942 TB / 12451840 TiB
NTFS at 333838/5/56
mftmirr_lcn               2
NTFS part_offset=2745911214080, part_size=4000650887168, sector_size=512
NTFS at 333838/5/56
mftmirr_lcn               2
     MS Data               5363107840 13176879103 7813771264
This partition ends after the disk limits. (start=5363107840, size=7813771264, end=13176879103, disk end=7814037168)
LVM magic value at 337131/125/13
SYSV4 Marker at 356450/82/18
recover_sysv4
     Unknown               5726374433 182349106464 176622732032 [ÿš&þ²C]
     Unknown               7622090673 29404521961611184 29404514339520512
NTFS at 486401/53/52
mft_lcn                   7864$MFT has invalid magic.
ntfs_mft_load(): Failed.
32
mftmirr_lcn               2
     MS Data                   264192 7814035455 7813771264
     NTFS found using backup sector, blocksize=4096, 4000 GB / 3725 GiB
mftmirr_lcn               2
NTFS: Can't read MFT
     MS Data               7814035455 15627806718 7813771264
This partition ends after the disk limits. (start=7814035455, size=7813771264, end=15627806718, disk end=7814037168)
file_win32_pread(92,11,buffer,3519069866(486401/80/58)) read err: read after end of file
file_win32_pread(92,8,buffer,3519069869(486401/80/61)) read err: read after end of file
file_win32_pread(92,14,buffer,3519069860(486401/80/52)) read err: read after end of file
file_win32_pread(92,14,buffer,3519069861(486401/80/53)) read err: read after end of file
file_win32_pread(92,14,buffer,3519069862(486401/80/54)) read err: read after end of file
file_win32_pread(92,14,buffer,3519069863(486401/80/55)) read err: read after end of file
file_win32_pread(92,14,buffer,3519069864(486401/80/56)) read err: read after end of file
file_win32_pread(92,14,buffer,3519069866(486401/80/58)) read err: read after end of file
file_win32_pread(92,14,buffer,3519069868(486401/80/60)) read err: read after end of file
file_win32_pread(92,14,buffer,3519069870(486401/80/62)) read err: read after end of file
The harddisk (4000 GB / 3726 GiB) seems too small! (< 8001 GB / 7451 GiB)
   P MS Data                   264192 7814035455 7813771264
 1 P MS Data                   264192 7814035455 7813771264
Best regards
Triangle
Re: 4TB external HDD / Win7 problem
You can choose to write the partition
In Advanced, choose BackupBS, confirm ad try RepairMFT.
If it doesn't work, please post the new log file. You may have to use PhotoRec to recover you data.
Triangle
#3 Post by Triangle »
Thanks a lot for the reply. Last action I did after running through your mentioned step was RepairMFT, it doesn't seem to work. Here's the log. By the way, there's only one Enctrypted Containerfile on the disk, but full size of the 4GB HDD.
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
recover_sysv4
mftmirr_lcn               2
mftmirr_lcn               2
NTFS at 285524/23/3
mftmirr_lcn               2
NTFS at 285524/23/3
mftmirr_lcn               2
NTFS at 333838/5/56
mftmirr_lcn               2
NTFS at 333838/5/56
mftmirr_lcn               2
recover_sysv4
32
mftmirr_lcn               2
mftmirr_lcn               2
recover_sysv4
mftmirr_lcn               2
mftmirr_lcn               2
NTFS at 285524/23/3
mftmirr_lcn               2
NTFS at 285524/23/3
mftmirr_lcn               2
NTFS at 333838/5/56
mftmirr_lcn               2
NTFS at 333838/5/56
mftmirr_lcn               2
recover_sysv4
32
mftmirr_lcn               2
mftmirr_lcn               2
file_win32_pread(92,11,buffer,3519069867(486401/80/59)) read err: read after end of file
file_win32_pread(92,8,buffer,3519069866(486401/80/58)) read err: read after end of file
file_win32_pread(92,8,buffer,3519069870(486401/80/62)) read err: read after end of file
file_win32_pread(92,14,buffer,3519069859(486401/80/51)) read err: read after end of file
gpt_change_part_type
Change partition type:
   P NTFS                      264192 7814035455 7813771264
write!
ntfs_boot_sector
NTFS at 16/113/34
filesystem size           9984105167889515364 7813771264
sectors_per_cluster       76 8
mft_lcn                   1265785050 786432
mftmirr_lcn               1747162029 2
clusters_per_mft_record   -124 -10
clusters_per_index_record 85 1
Status: Bad
Warning: number of heads/cylinder mismatches 16 (NTFS) != 255 (HD)
Status: OK
Sectors are not identical.
copy backup boot sector over boot sector
ntfs_boot_sector
NTFS at 16/113/34
NTFS at 16/113/34
mftmirr_lcn               2
Status: OK
Status: OK
Sectors are identical.
ntfs_boot_sector
NTFS at 16/113/34
NTFS at 16/113/34
mftmirr_lcn               2
Status: OK
Status: OK
repair_MFT
NTFS at 16/113/34
ntfs_boot_sector
NTFS at 16/113/34
NTFS at 16/113/34
mftmirr_lcn               2
Status: OK
Status: OK
Due to the crypto, I have no solution.
Sorry
Triangle
#5 Post by Triangle »
Anyway, thank you for your support. I appreciate your work! Thread can be closed.
