[I apologise for the long post, I tried to provide as much information as possible]
I have a laptop with two internal hard drives. One is a 500GB Hitachi drive which I use as a storage drive (the system is on the other one). I made a mistake when trying to reformat a thumb drive and reformatted my 500GB drive instead. I immediately unmounted the drive and did not touch it again.
The drive used to have a single ~500GB HFS+ journaled partition with a GUID partition table. It now has a single ~500GB FAT32 partition with a (new) GUID partition table. (NB: the laptop is a MacBook Pro and the formatting was done with Disk Utility). It was a quick reformat (took a few seconds) of the whole drive (not just the partition), which is why I assume the partition table has been completely rewritten but the data should still be there.
According to this:
http://www.cgsecurity.org/wiki/Data_Rec ... _partition
it seems possible to recover the old partition as it was. It would be ideal for me since that drive had quite many files, including my photo archive. A file based recovery, even if it does recover all files, would require to rename all of them which would be nearly unfeasible.
I made a block-level copy of the 500GB drive to an external drive, with dd, just to be safe, and then started following the instructions above. Here is what I get:
 Disk /dev/disk0 - 251 GB / 233 GiB (RO)
>Disk /dev/disk1 - 500 GB / 465 GiB
 Disk /dev/rdisk0 - 251 GB / 233 GiB (RO)
 Disk /dev/rdisk1 - 500 GB / 465 GiB
>[Proceed ]  [  Quit  ]
The partition table type is correctly detected
 [Intel  ] Intel/PC partition
>[EFI GPT] EFI GPT partition map (Mac i386, some x86_64...)
 [Humax  ] Humax partition table
 [Mac    ] Apple partition map
 [None   ] Non partitioned media
 [Sun    ] Sun Solaris partition
 [XBox   ] XBox partition
Hint: EFI GPT partition table type has been detected.
     976773168 sectors - sector size=512
 [ Analyse  ] Analyse current partition structure and search for lost partitions
>[ Advanced ] Filesystem Utils
 [ Options  ] Modify options
 [ Quit     ] Return to disk selection
Disk /dev/disk1 - 500 GB / 465 GiB - 976773168 sectors
  1 P EFI System                    40     409639     409600
> 2 P MS Data                   409640  976510983  976101344 [ARCHIVE]
>[  Type  ]  [  Boot  ]  [Undelete]  [Image Creation]  [  Quit  ]
Please choose the partition type, press Enter when done.
 EFI System                HPUX Data                 Solaris /home
 MBR                       HPUX Service              Solaris EFI Alt.
 FreeBSD                  >Mac HFS                   Solaris Reserved1
 FreeBSD Swap              Mac UFS                   Solaris Reserved2
 FreeBSD UFS               Mac Raid                  Solaris Reserved3
 FreeBSD Vinum             Mac Raid (Offline)        Solaris Reserved4
 FreeBSD ZFS               Mac Boot                  Solaris Reserved5
 MS Reserved               Mac Label
 MS Data                   Mac TV Recovery
 MS LDM MetaData           Solaris /boot
 MS LDM Data               Solaris /
 Linux Raid                Solaris Swap
 Linux Swap                Solaris Backup
 Linux LVM                 Solaris /usr
 Linux Reserved            Solaris /var
[ Proceed ]
 2 P FAT32                     409640  976510983  976101344 [ARCHIVE]
 Unknown                   HFSX                      NTFS
 BeFS                      HPFS                      OpenBSD
 btrfs                     ISO                       OS2 Multiboot
 CramFS                    JFS                       ReiserFS 3.5
 exFAT                     Linux SWAP                ReiserFS 3.6
 ext2                      Linux SWAP 2              ReiserFS 3.x
 ext3                      Linux SWAP                ReiserFS 4
 ext4                      Linux SWAP 2              Sun
 FAT12                     Linux SWAP 2              SysV 4
 FAT16                     Linux LUKS                UFS
 FAT32                     Linux LVM                 UFS 2
 FreeBSD                   Linux LVM2                UFS - Little Endian
 GFS2                      Linux md 0.9 RAID         UFS 2 - Little Endian
 HFS                       Linux md 1.x RAID         VMFS
>HFS+                      Netware                   WBFS
                                                     Next
[ Proceed ]
> 2 P Mac HFS                   409640  976510983  976101344 [ARCHIVE]
 [  Type  ] >[Superblock]  [Image Creation]  [  Quit  ]
                      Locate HFS/HFS+ backup volume header
Volume header
Bad
Backup volume header
Bad
Sectors are identical.
>[  Quit  ]  [  Dump  ]
So I tried changing the type through the regular menu:
Warning: number of heads/cylinder mismatches 255 (FAT) != 1 (HD)
Warning: number of sectors per track mismatches 32 (FAT) != 1 (HD)
                P=Primary  D=Deleted
>[Quick Search]  [ Backup ]
Analyse cylinder 976683008/976773167: 99%
Warning: number of heads/cylinder mismatches 16 (FAT) != 1 (HD)
  EFI System                    40     409639     409600 [EFI]
  Stop
 P EFI System                    40     409639     409600 [EFI]
                P=Primary  D=Deleted
     Enter: to continue
FAT32, blocksize=32768, 499 GB / 465 GiB
                P=Primary  D=Deleted
Keys A: add partition, L: load backup, T: change type,
     Enter: to continue
 1 P EFI System                    40     409639     409600 [EFI]
 [  Quit  ]  [Deeper Search] >[ Write  ]
                       Write partition structure to disk
Write partition table, confirm ? (Y/N)
>[Ok]
No HFS or HFS+ structure
At that point I proceeded with a Deep Scan, just to see what it would give and here is the result:
The harddisk (500 GB / 465 GiB) seems too small! (< 14117418 TB / 12839717 TiB)
>  MS Data                721131259 27573082889725481 27573082168594222
   Mac HFS                859347305 1835448648  976101344
   Mac HFS                859347410 1835448753  976101344
   Mac HFS                859347499 1835448842  976101344
   Mac HFS                859347684 1835449027  976101344
   Mac HFS                859347957 1835449300  976101344
   Mac HFS                859348358 1835449701  976101344
   Mac HFS                859348647 1835449990  976101344
   Mac HFS                859349528 1835450871  976101344
   Mac HFS                859349761 1835451104  976101344
[ Continue ]
JFS 1162430030, blocksize=1431522668, 14117418 TB / 12839716 TiB
HFS+ blocksize=4096, 499 GB / 465 GiB
I don't know how important is the warning regarding the size of the disk. It is indeed 500GB. The sizes in TB mentioned on the same line are unrealistic.
When I hit continue I get to:
 D EFI System                    40     409639     409600 [EFI]
 D EFI System                    46     409645     409600 [EFI]
>D MS Data                   409640  976510983  976101344 [ARCHIVE]
 D MS Data                   409646  976510989  976101344 [ARCHIVE]
 D Mac HFS                 18580459   19406650     826192
 D Mac HFS                 19406647   20232838     826192
 D Mac HFS                 58113610   69873077   11759468
 D Mac HFS                 69873074   81632541   11759468
 D Mac HFS                130673441  130880064     206624
 D Mac HFS                130673467  130880090     206624
 D Mac HFS                130673468  130880091     206624
 D Mac HFS                130673501  130880124     206624
 D Mac HFS                130673555  130880178     206624
 D Mac HFS                130675496  130880063     204568
 D Mac HFS                130841056  131047679     206624
 D Mac HFS                130843113  131047680     204568
 D Mac HFS                130880060  131084627     204568
 D Mac HFS                130880061  131086684     206624
 D Mac HFS                130880087  131086710     206624
 D Mac HFS                130880088  131086711     206624
 D Mac HFS                130880121  131086744     206624
 D Mac HFS                130880175  131086798     206624
 D Mac HFS                131047676  131254299     206624
 D Mac HFS                131047677  131252244     204568
 D Mac HFS                144864668  144894715      30048
 D Mac HFS                144894712  144924759      30048
 D Mac HFS                146902000  146932047      30048
 D Mac HFS                146932044  146962091      30048
 D Mac HFS                154287518  155311437    1023920
 D Mac HFS                154534388  155558307    1023920
 D Mac HFS                155311434  156335353    1023920
 D Mac HFS                155558304  156582223    1023920
 D Mac HFS                220753300  220763539      10240
 D Mac HFS                220758402  220768641      10240
 D Mac HFS                220763536  220773775      10240
 D Mac HFS                220768638  220778877      10240
 D Mac HFS                221558538  221568771      10234 [Toolbox]
 D Mac HFS                221558716  221568859      10144
 D Mac HFS                221568768  221579001      10234 [Toolbox]
 D Mac HFS                221568774  221579007      10234 [Toolbox]
 D Mac HFS                221568856  221578999      10144
 D Mac HFS                221578996  221589139      10144
 D Mac HFS                221579004  221589237      10234 [Toolbox]
 D Mac HFS                221812658  221817163       4506 [PL2303 driver]
 D Mac HFS                221812836  221817251       4416
 D Mac HFS                221813953  221818458       4506 [PL2303 driver]
 D Mac HFS                221814042  221818457       4416
 D Mac HFS                221817160  221821665       4506 [PL2303 driver]
 D Mac HFS                221817248  221821663       4416
 D Mac HFS                221818454  221822869       4416
 D Mac HFS                221818455  221822960       4506 [PL2303 driver]
 D Mac HFS                323651004  335410471   11759468
 D Mac HFS                335410468  347169935   11759468
 D MS Data                700266254  700475117     208864
 D MS Data                700266336  700475199     208864
 D MS Data                714366328  714369207       2880 [NO NAME]
 D Mac HFS                793292520  793317839      25320
 D Mac HFS                793317836  793343155      25320
 D Mac HFS                826279657  826284162       4506 [PL2303 driver]
 D Mac HFS                826279746  826284161       4416
 D Mac HFS                826284158  826288573       4416
 D Mac HFS                826284159  826288664       4506 [PL2303 driver]
 D Mac HFS                940385419  940578019     192601 [Corel Painter 8]
 D Mac HFS                940578016  940770616     192601 [Corel Painter 8]
 D Mac HFS                940578152  940770752     192601 [Corel Painter 8]
 D Mac HFS                940770749  940963349     192601 [Corel Painter 8]
 D Mac HFS                949231804  950370547    1138744
 D Mac HFS                950370544  951509287    1138744
>D Mac HFS                951509284  952648027    1138744
                P=Primary  D=Deleted
     Enter: to continue
                P=Primary  D=Deleted
     Enter: to continue
HFS+ blocksize=4096, 583 MB / 556 MiB
Many of the small HFS partitions appear to be disk images of applications, which were indeed on the disk, and are duplicated (see [Corel Painter 8]).
I don't know what to do at this point. Can I rewrite the partition table manually assuming some of the sizes? Did I do something wrong in TestDisk? I would welcome all advice. I am no expert but I am not scared of the command line. I have Linux and Windows machines handy if needed.
The data on this drive is quite important to me (I thought it was backed up and it was not completely...) so thank you very much in advance.
