Bad ending head/Can't open filesystem. Filesystem seems damaged.
historybuff3737
#1 Post by historybuff3737 »
My Windows 10 no longer boots up; my C: drive comes up as RAW. I was able to run a deeper search using TestDisk, but had this warning at the start: Warning: Bad ending head (CHS and LBA don't match). At the end of the deeper search, I can't access the files (by pressing p) in the RAW partition - I just get this message: Can't open filesystem. Filesystem seems damaged. I am not seeing any green text, nor an option to write the partition table. The log is below. Is there anything else I can do? Maybe resolve the CHS/LBA issue before the deeper scan? Any help would be much appreciated since this is my personal laptop and has a lot of of files that are important to me. Many thanks in advance!
Wed Nov 29 10:50:42 2017
TestDisk 7.1-WIP, Data Recovery Utility, November 2017
OS: Windows 8 (9200)
Compiler: GCC 5.4, Cygwin 2005.2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=7747397632
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=7747397632
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=970769229312
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=27237810176
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=7746568704
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=997195776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\X:)=3162112
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - TOSHIBA MQ01ABD100, S/N:739PP1QIT, FW:AX001C
Disk /dev/sdb - 7747 MB / 7388 MiB - CHS 941 255 63, sector size=512 - Kingston DataTraveler 2.0, S/N:6, FW:1.00
Drive X: - 3162 KB / 3088 KiB - CHS 193 16 2, sector size=512 - Microsoft Corporation RamDisk
Disk /dev/sda - 1000 GB / 931 GiB - TOSHIBA MQ01ABD100
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
NTFS at 0/32/33
filesystem size 819200
mft_lcn 34133
mftmirr_lcn 2
HPFS - NTFS 0 32 33 51 30 43 819200 [WINRE]
NTFS, blocksize=4096, 419 MB / 400 MiB
FAT32 at 51/30/44
FAT1 : 7166-7678
FAT2 : 7679-8191
Data : 8192-532479
sectors : 532480
cluster_size : 8
no_of_cluster : 65536 (2 - 65537)
fat_length 513 calculated 513
FAT32 at 51/30/44
FAT: cluster=2(0x2), pos=829440
FAT32 51 30 44 84 67 47 532480 [EFI System Partition] [NO NAME]
FAT32, blocksize=4096, 272 MB / 260 MiB
NTFS at 100/148/49
filesystem size 1896033651
mftmirr_lcn 2
HPFS - NTFS 100 148 49 118123 55 63 1896033651
NTFS, blocksize=4096, 970 GB / 904 GiB
NTFS at 118123/66/24
filesystem size 1947648
mft_lcn 81152
mftmirr_lcn 2
HPFS - NTFS 118123 66 24 118244 126 26 1947648
NTFS, blocksize=4096, 997 MB / 951 MiB
NTFS at 118244/126/27
filesystem size 716800
mft_lcn 29866
mftmirr_lcn 2
HPFS - NTFS 118244 126 27 118289 29 12 716800
NTFS, blocksize=4096, 367 MB / 350 MiB
NTFS at 118289/29/13
filesystem size 53198848
mftmirr_lcn 2
HPFS - NTFS 118289 29 13 121600 150 22 53198848 [RECOVERY]
NTFS, blocksize=4096, 27 GB / 25 GiB
file_pread(4,2,buffer,1953525759(121601/90/25)) lseek err Invalid argument
file_pread(4,1,buffer,1953525759(121601/90/25)) lseek err Invalid argument
file_pread(4,2,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(4,14,buffer,1953525762(121601/90/28)) lseek err Invalid argument
file_pread(4,3,buffer,1953525776(121601/90/42)) lseek err Invalid argument
file_pread(4,3,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(4,8,buffer,1953525839(121601/91/42)) lseek err Invalid argument
file_pread(4,11,buffer,1953525886(121601/92/26)) lseek err Invalid argument
file_pread(4,2,buffer,1953527808(121601/122/58)) lseek err Invalid argument
HPFS - NTFS 100 148 49 118123 66 23 1896034304
$MFT has invalid magic.
ntfs_mft_load(): Failed.
NTFS at 0/32/33
mft_lcn 34133
mftmirr_lcn 2
NTFS at 51/30/43
mft_lcn 34133
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 419 MB / 400 MiB
FAT32 at 51/30/44
FAT1 : 7166-7678
FAT2 : 7679-8191
Data : 8192-532479
sectors : 532480
cluster_size : 8
FAT32 at 51/30/44
FAT32 at 51/30/50
FAT1 : 7166-7678
FAT2 : 7679-8191
Data : 8192-532479
sectors : 532480
cluster_size : 8
FAT differs, FAT sectors=496-512/513
FAT32 at 51/30/50
NTFS at 100/148/49
mftmirr_lcn 2
mft_lcn 81152
mftmirr_lcn 2
NTFS at 118244/126/26
mft_lcn 81152
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 997 MB / 951 MiB
mft_lcn 29866
mftmirr_lcn 2
NTFS at 118289/29/12
mft_lcn 29866
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 367 MB / 350 MiB
mftmirr_lcn 2
NTFS at 121600/150/22
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 27 GB / 25 GiB
dir_partition inode=0
3 drwxr-xr-x 0 0 0 22-Oct-2017 19:26 EFI
9605 drwxr-xr-x 0 0 0 25-Jul-2013 12:27 BOOT
X 24012 -rwxr-xr-x 0 0 12288 25-Jul-2013 12:39 _CD
X 24014 -rwxr-xr-x 0 0 12288 25-Jul-2013 12:39 _CD.LOG
15457 -r-xr-xr-x 0 0 512 2-Aug-2015 09:38 BOOTSECT.BAK
Not an exFAT boot sector.
Re: Bad ending head/Can't open filesystem. Filesystem seems damaged.
Use EFI partition table type.
historybuff3737
#3 Post by historybuff3737 »
Many thanks! I should have noticed that it detected EFI partition type. I completed another deeper scan and got this message at the end:
The harddisk (1000 GB / 931 GiB) seems too small! (< 1942 GB / 1808 GiB)
The following partitions can't be recovered...
As always, any advice would be much appreciated. Amended log is below (full log exceeds number of allowed characters). Many thanks!
Thu Nov 30 10:37:22 2017
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=1953525167 (expected 1953525167)
hdr_lba_start=34
hdr_lba_end=1953525134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
3 P MS Reserved 1353728 1615871 262144 [Microsoft reserved partition]
1 P Unknown 2048 821247 819200 [Basic data partition]
2 P EFI System 821248 1353727 532480 [EFI system partition]
4 P MS Data 1615872 1897649522 1896033651 [Basic data partition]
5 P Unknown 1897650176 1899597823 1947648
6 P Unknown 1899597824 1900314623 716800
7 P MS Data 1900314624 1953513471 53198848 [Basic data partition] [RECOVERY]
NTFS at 0/32/33
mft_lcn 34133
mftmirr_lcn 2
NTFS part_offset=1048576, part_size=419430400, sector_size=512
NTFS at 0/32/33
mft_lcn 34133
mftmirr_lcn 2
MS Data 2048 821247 819200 [WINRE]
FAT32 at 51/30/44
FAT1 : 7166-7678
FAT2 : 7679-8191
Data : 8192-532479
sectors : 532480
cluster_size : 8
FAT32 at 51/30/44
EFI System 821248 1353727 532480 [EFI System Partition] [NO NAME]
NTFS at 100/148/49
mftmirr_lcn 2
NTFS part_offset=827326464, part_size=970769229312, sector_size=512
NTFS at 100/148/49
mftmirr_lcn 2
mft_lcn 81152
mftmirr_lcn 2
MS Data 1895702529 1897650176 1947648
mft_lcn 81152
mftmirr_lcn 2
MS Data 1897650176 1899597823 1947648
mft_lcn 29866
mftmirr_lcn 2
MS Data 1898881025 1899597824 716800
mft_lcn 29866
mftmirr_lcn 2
MS Data 1899597824 1900314623 716800
mftmirr_lcn 2
MS Data 1847115777 1900314624 53198848
mftmirr_lcn 2
MS Data 1900314624 1953513471 53198848 [RECOVERY]
file_pread(4,1,buffer,1953525168(121601/81/1)) ReadFile Incorrect function.
file_pread(4,1,buffer,1953525169(121601/81/2)) lseek err Invalid argument
file_pread(4,1,buffer,1953525170(121601/81/3)) lseek err Invalid argument
file_pread(4,1,buffer,1953525171(121601/81/4)) lseek err Invalid argument
FAT: cluster=1578(0x62a), pos=973880
MS Data 953080 1485559 532480 [NO NAME]
NTFS at 59/85/51
filesystem size 6174
sectors_per_cluster 1
mft_lcn 2058
mftmirr_lcn 5162
clusters_per_mft_record 2
clusters_per_index_record 8
MS Data 947067 953240 6174
NTFS at 59/85/51
mft_lcn 2058
mftmirr_lcn 5162
MS Data 953240 959413 6174 [Boot]
NTFS at 62/26/45
mft_lcn 2058
mftmirr_lcn 5162
MS Data 991539 997712 6174
NTFS at 62/26/45
mft_lcn 2058
mftmirr_lcn 5162
MS Data 997712 1003885 6174 [Boot]
NTFS at 100/148/49
mftmirr_lcn 2
NTFS at 100/148/49
mftmirr_lcn 2
LVM magic value at 1342/247/58
HFS magic value at 1343/101/14
part_size 469763330
Mac HFS 21581671 491345000 469763330
HFS blocksize=67108864, 240 GB / 224 GiB
HFS magic value at 1343/101/16
NTFS at 2775/4/62
filesystem size 102400000
mftmirr_lcn 2
NTFS part_offset=22825312256, part_size=52428800000, sector_size=512
NTFS at 2775/4/62
mftmirr_lcn 2
MS Data 44580688 146980687 102400000
NTFS, blocksize=4096, 52 GB / 48 GiB
LVM magic value at 3839/159/57
HFS magic value at 3840/13/13
part_size 469763330
Mac HFS 61690431 531453760 469763330
HFS magic value at 3840/13/15
FAT12 at 4131/106/32
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
fat_length 9 calculated 9
EFI System 66371224 66374103 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 4381/227/43
check_FAT: Unusual media descriptor (0xf8!=0xf0)
FAT1 : 1-8
FAT2 : 9-16
start_rootdir : 17
Data : 49-20736
sectors : 20739
cluster_size : 8
no_of_cluster : 2586 (2 - 2587)
fat_length 8 calculated 8
FAT differs, FAT sectors=0-8/8
heads/cylinder 4 (FAT) != 255 (HD)
sect/track 17 (FAT) != 63 (HD)
MS Data 70395108 70415846 20739 [NO NAME]
check_FAT: Unusual, only one FAT
FAT32 at 4381/227/44
check_FAT: Bad number of entries in root dir
FAT12 at 4574/86/33
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 at 4574/86/33
EFI System 73486760 73489639 2880 [EFI System Partition] [EFISECTOR]
HFS magic value at 5905/64/56
part_size 10538
Mac HFS 94867912 94878449 10538 [SimTowerR]
HFS blocksize=2048, 5395 KB / 5269 KiB
HFS magic value at 5905/64/58
part_size 10538
Mac HFS 94857378 94867915 10538 [SimTowerR]
HFS found using backup sector!, 5395 KB / 5269 KiB
HFS magic value at 5905/232/6
part_size 10538
Mac HFS 94878446 94888983 10538 [SimTowerR]
HFS magic value at 5905/232/8
part_size 10538
LVM magic value at 10646/131/29
LVM magic value at 11731/18/8
HFS magic value at 11731/126/27
part_size 469763330
Mac HFS 188466479 658229808 469763330
HFS magic value at 11731/126/29
NTFS at 24127/50/4
filesystem size 78124993
mftmirr_lcn 16
MS Data 309478416 387603408 78124993
NTFS found using backup sector, blocksize=4096, 39 GB / 37 GiB
NTFS at 24127/50/4
mftmirr_lcn 16
MS Data 387603408 465728400 78124993
NTFS, blocksize=4096, 39 GB / 37 GiB
NTFS at 24127/50/5
filesystem size 3357522
sectors_per_cluster 2
mft_lcn 16
mftmirr_lcn 839380
clusters_per_mft_record 1
clusters_per_index_record 4
MS Data 384245888 387603409 3357522
NTFS found using backup sector, blocksize=1024, 1719 MB / 1639 MiB
NTFS at 24127/50/5
mft_lcn 16
mftmirr_lcn 839380
MS Data 387603409 390960930 3357522
NTFS, blocksize=1024, 1719 MB / 1639 MiB
FAT16 at 24127/50/6
FAT1 : 1-249
FAT2 : 250-498
start_rootdir : 499
Data : 531-2040178
sectors : 2040192
cluster_size : 32
no_of_cluster : 63739 (2 - 63740)
fat_length 249 calculated 249
FAT differs, FAT sectors=0-16/249
FAT16 at 24127/50/6
MS Data 387603410 389643601 2040192
FAT16, blocksize=16384, 1044 MB / 996 MiB
FAT16 at 24128/58/57
FAT1 : 1-249
FAT2 : 250-498
start_rootdir : 499
Data : 531-2040178
sectors : 2040192
cluster_size : 32
MS Data 387620030 389660221 2040192 [NO NAME]
cramfs Marker at 31097/56/41
recover_cramfs
MS Data 499576873 500948856 1371983 [GW¹¤Ø«ÝнÍ(bždSÜ]
cramfs, 702 MB / 669 MiB
cramfs Marker at 31097/56/42
recover_cramfs
MS Data 499576874 500948857 1371983 [GW¹¤Ø«ÝнÍ(bždSÜ]
LVM magic value at 39857/173/21
LVM magic value at 40457/125/58
SYSV4 Marker at 47427/245/24
recover_sysv4
Unknown 761930213 2328175290852 2327413360640 []°É1Ó]
SysV4, 1191 TB / 1083 TiB
Partition not added.
LVM magic value at 51867/159/24
FAT12 at 55285/211/15
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT differs, FAT sectors=0-9/9
MS Data 888166832 888169711 2880 [EFISECTOR]
FAT12 at 64095/120/18
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
MS Data 1029693752 1029696631 2880 [EFISECTOR]
NTFS at 64099/235/9
mftmirr_lcn 2
NTFS part_offset=527239806976, part_size=970769229312, sector_size=512
NTFS at 64099/235/9
mftmirr_lcn 2
MS Data 1029765248 2925798898 1896033651
This partition ends after the disk limits. (start=1029765248, size=1896033651, end=2925798898, disk end=1953525168)
NTFS at 64138/94/53
mftmirr_lcn 16
MS Data 952257952 1030382944 78124993
NTFS at 64138/94/53
mftmirr_lcn 16
MS Data 1030382944 1108507936 78124993
NTFS at 64138/94/54
mft_lcn 16
mftmirr_lcn 839380
MS Data 1027025424 1030382945 3357522
NTFS at 64138/94/54
mft_lcn 16
mftmirr_lcn 839380
MS Data 1030382945 1033740466 3357522
FAT16 at 64138/94/55
FAT1 : 1-249
FAT2 : 250-498
start_rootdir : 499
Data : 531-2040178
sectors : 2040192
cluster_size : 32
MS Data 1030382946 1032423137 2040192
LVM magic value at 73172/102/59
Unknown 1176625679 4600036921 3423411243
FATX, 1752 GB / 1632 GiB
NTFS at 74407/155/21
mftmirr_lcn 2
NTFS part_offset=612023418880, part_size=970769229312, sector_size=512
mftmirr_lcn 2
MS Data 1195358240 3091391890 1896033651
This partition ends after the disk limits. (start=1195358240, size=1896033651, end=3091391890, disk end=1953525168)
NTFS at 84310/134/35
mftmirr_lcn 2
NTFS part_offset=693477696512, part_size=970769229312, sector_size=512
mftmirr_lcn 2
MS Data 1354448626 3250482276 1896033651
This partition ends after the disk limits. (start=1354448626, size=1896033651, end=3250482276, disk end=1953525168)
FAT12 at 93472/186/35
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
EFI System 1501639432 1501642311 2880 [EFI System Partition] [EFISECTOR]
LVM magic value at 95927/41/43
NTFS at 118123/55/63
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 970 GB / 904 GiB
mftmirr_lcn 2
MS Data 1897649522 3793683172 1896033651
This partition ends after the disk limits. (start=1897649522, size=1896033651, end=3793683172, disk end=1953525168)
mft_lcn 81152
mftmirr_lcn 2
mft_lcn 81152
mftmirr_lcn 2
NTFS at 118123/202/24
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1897652571 1897658744 6174
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1897658744 1897664917 6174 [Boot]
NTFS at 118132/49/22
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1897787515 1897793688 6174
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1897793688 1897799861 6174 [Boot]
NTFS at 118163/19/33
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1898283651 1898289824 6174
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1898289824 1898295997 6174 [Boot]
NTFS at 118168/132/37
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1898371099 1898377272 6174
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1898377272 1898383445 6174 [Boot]
mft_lcn 81152
mftmirr_lcn 2
mft_lcn 81152
mftmirr_lcn 2
MS Data 1899597823 1901545470 1947648
mft_lcn 29866
mftmirr_lcn 2
mft_lcn 29866
mftmirr_lcn 2
NTFS at 118254/23/50
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1899745835 1899752008 6174
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1899752008 1899758181 6174 [Boot]
mft_lcn 29866
mftmirr_lcn 2
mft_lcn 29866
mftmirr_lcn 2
MS Data 1900314623 1901031422 716800
mftmirr_lcn 2
mftmirr_lcn 2
NTFS at 118391/17/51
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1901946363 1901952536 6174
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1901952536 1901958709 6174 [Boot]
NTFS at 118392/95/56
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1901967347 1901973520 6174
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1901973520 1901979693 6174 [Boot]
NTFS at 118678/250/45
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1906571691 1906577864 6174
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1906577864 1906584037 6174 [Boot]
NTFS at 121516/137/62
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1952157059 1952163232 6174
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1952163232 1952169405 6174 [Boot]
mftmirr_lcn 2
mftmirr_lcn 2
file_pread(4,2,buffer,1959804933(121992/54/52)) lseek err Invalid argument
file_pread(4,1,buffer,1959804933(121992/54/52)) lseek err Invalid argument
NTFS: Can't read MFT
MS Data 1953513471 2006712318 53198848
This partition ends after the disk limits. (start=1953513471, size=53198848, end=2006712318, disk end=1953525168)
file_pread(4,2,buffer,1953525181(121601/81/14)) lseek err Invalid argument
file_pread(4,1,buffer,1953525185(121601/81/18)) lseek err Invalid argument
file_pread(4,1,buffer,1953525232(121601/82/2)) lseek err Invalid argument
file_pread(4,8,buffer,1953525246(121601/82/16)) lseek err Invalid argument
file_pread(4,11,buffer,1953525293(121601/82/63)) lseek err Invalid argument
file_pread(4,1,buffer,1953527216(121601/113/33)) lseek err Invalid argument
file_pread(4,14,buffer,1953525170(121601/81/3)) lseek err Invalid argument
file_pread(4,1,buffer,1953525186(121601/81/19)) lseek err Invalid argument
file_pread(4,1,buffer,1953525233(121601/82/3)) lseek err Invalid argument
file_pread(4,1,buffer,1953525254(121601/82/24)) lseek err Invalid argument
file_pread(4,1,buffer,1953525304(121601/83/11)) lseek err Invalid argument
file_pread(4,1,buffer,1953527217(121601/113/34)) lseek err Invalid argument
MS Data 84347 90520 6174
MS Data 90520 96693 6174 [Boot]
MS Data 821247 1640446 819200
MS Data 821254 1353733 532480 [NO NAME]
MS Data 499576873 500948856 1371984 [GW¹¤Ø«ÝнÍ(bždSÜ]
MS Data 499576874 500948857 1371984 [GW¹¤Ø«ÝнÍ(bždSÜ]
Run TestDisk, EFI GPT, Advanced, select the partition tC:, Boot, RebuildBS, List. If you can see your files, choose Write, confirm, Quit
If it doesn't work, run "cmd" (right click run as administrator) and "chkdsk /f c:" (replace c: if necessary).
What are the results ?
historybuff3737
#5 Post by historybuff3737 »
Thank you so much for your help, it is greatly appreciated. Unfortunately I couldn't see my files ("Can't open filesystem. Filesystem seems damaged.")
chkdsk c: resulted in the following: "Unable to determine volume version and state. CHKDSK aborted".
diskpart shows Volume 0 as Ltr C; Fs RAW; Type Partition; Size 904 GB; Status Healthy.
Testdisk log is below. What else should I try? Many thanks!
Mon Dec 4 10:38:06 2017
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
ntfs_boot_sector
NTFS at 100/148/49
NTFS at 100/148/49
mftmirr_lcn 2
Status: OK
Status: OK
Sectors are identical.
rebuild_NTFS_BS
mft at 1000616864
read_mft_info failed
ntfs_find_mft: sectors_per_cluster invalid
ntfs_find_mft: mft_lcn 786432
ntfs_find_mft: mftmirr_lcn 2
mft at 1002243424
mft at 1012863168
mft at 1028149392
mft at 1193742384
ntfs_boot_sector
NTFS at 100/148/49
NTFS at 100/148/49
mftmirr_lcn 2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 100/148/49
NTFS at 100/148/49
mftmirr_lcn 2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 100/148/49
NTFS at 100/148/49
mftmirr_lcn 2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 100/148/49
NTFS at 100/148/49
mftmirr_lcn 2
Status: OK
Status: OK
historybuff3737
#6 Post by historybuff3737 »
Hi there, do you have any other suggestions for what I can try in order to recover my partition using TestDisk? Any help would be greatly appreciated. Many thanks!
