I rebooted my machine and the disk has come back RAW.
I am in the process of doing a Deep Scan, but my question is...
When I ran Testdisk it said there were parameters on the disk that were wrong.
Boot Sector seems ok and Backup seems ok.
Disk comes back GPT which is correct but it is saying it is a MSData.
Says MFT and backup are screwed up.
With the parameters of the driving showing weird, could it be looking in the wrong sector for the MFT?
The drive hasn't tried to chkdsk nor has it asked me to format. Just says "parameter is incorrect" in windows.
Her is my log:
Fri Dec 1 09:48:09 2017
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=128035676160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=128035676160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdf)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdg)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdh)=3000504418304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdi)=3000504418304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdj)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdk)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdl)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdm)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=128035676160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive7)=3000504418304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive8)=3000504418304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive9)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive10)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive11)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive12)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=126767120384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=128033226752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000194048000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=3000502321152
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=3000501272576
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=2000311812096
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=2000311812096
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=2000311812096
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=2000311812096
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=2000311812096
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=2000311812096
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\N:)=3000591450112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\O:)=500105740288
filewin32_getfilesize(\\.\Z:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\Z:) SetFilePointer err Incorrect function.
Warning: can't get size for \\.\Z:
Disk /dev/sda - 128 GB / 119 GiB - CHS 72736 191 18, sector size=512
Disk /dev/sdb - 128 GB / 119 GiB - CHS 15566 255 63, sector size=512
Disk /dev/sdc - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512
Disk /dev/sdd - 2000 GB / 1862 GiB - CHS 243190 255 63, sector size=512
Disk /dev/sde - 2000 GB / 1862 GiB - CHS 243190 255 63, sector size=512
Disk /dev/sdf - 2000 GB / 1862 GiB - CHS 243190 255 63, sector size=512
Disk /dev/sdg - 2000 GB / 1862 GiB - CHS 243190 255 63, sector size=512
Disk /dev/sdh - 3000 GB / 2794 GiB - CHS 364790 255 63, sector size=512
Disk /dev/sdi - 3000 GB / 2794 GiB - CHS 364790 255 63, sector size=512
Disk /dev/sdj - 2000 GB / 1862 GiB - CHS 243190 255 63, sector size=512
Disk /dev/sdk - 2000 GB / 1862 GiB - CHS 243190 255 63, sector size=512
Disk /dev/sdl - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk /dev/sdm - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Drive C: - 126 GB / 118 GiB - CHS 72016 191 18, sector size=512
Drive D: - 128 GB / 119 GiB - CHS 15565 255 63, sector size=512
Drive E: - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512
Drive F: - 3000 GB / 2794 GiB - CHS 364790 255 63, sector size=512
Drive G: - 3000 GB / 2794 GiB - CHS 364790 255 63, sector size=512
Drive H: - 2000 GB / 1862 GiB - CHS 243190 255 63, sector size=512
Drive N: - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512
Drive O: - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Partition table type: EFI GPT
Analyse Disk /dev/sdh - 3000 GB / 2794 GiB - CHS 364790 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=5860360191 (expected 5860360191)
hdr_lba_start=34
hdr_lba_end=5860360158
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P MS Data 2048 5860358143 5860356096 [Basic data partition]
NTFS at 0/32/33
filesystem size 5860356089
mft_lcn 22359
mftmirr_lcn 22358
NTFS part_offset=1048576, part_size=3000502317568, sector_size=512
NTFS at 0/32/33
mft_lcn 22359
mftmirr_lcn 22358
MS Data 2048 5860358136 5860356089
NTFS at 364790/107/53
mft_lcn 22359
mftmirr_lcn 22358
MS Data 2055 5860358143 5860356089
NTFS found using backup sector, blocksize=4096, 3000 GB / 2794 GiB
mft_lcn 22359
mftmirr_lcn 22358
file_pread(11,1024,buffer,1565572791(364801/190/53)) lseek err Invalid argument
file_pread(11,1,buffer,1565572791(364801/190/53)) lseek err Invalid argument
NTFS: Can't read MFT
MS Data 5860358143 11720714231 5860356089
This partition ends after the disk limits. (start=5860358143, size=5860356089, end=11720714231, disk end=5860360192)
file_pread(11,1,buffer,1565392896(364790/140/23)) ReadFile Incorrect function.
file_pread(11,1,buffer,1565394579(364790/167/5)) lseek err$MFT has invalid magic.
ntfs_mft_load(): Failed.
Invalid argument
file_pread(11,1,buffer,1565394580(364790/167/6)) lseek err Invalid argument
file_pread(11,1,buffer,1565394581(364790/167/7)) lseek err Invalid argument
file_pread(11,1,buffer,1565393032(364790/142/33)) lseek err Invalid argument
file_pread(11,1,buffer,1565394945(364790/172/56)) lseek err Invalid argument
The harddisk (3000 GB / 2794 GiB) seems too small! (< 6001 GB / 5588 GiB)
Reboot Raw Disk
Re: Reboot Raw Disk
Run "cmd" (right click run as administrator) and "chkdsk /f d:" (replace d: by the correct drive letter).
What is the results ?
grumbleskin
Re: Reboot Raw Disk
The type of file system is NTFS.
Unable to determine volume version and state. CHKDSK aborted.
Re: Reboot Raw Disk
You can use PhotoRec to recover your data but it will not recover the original filenames. You can also try some commercial data recovery utilities, they may have better success in recovering the original file hierarchy.
