change name extension ".txt" to ".gnd"
zagato
#1 Post by zagato »
Hello everyone.
The situation ... I had some text files (.txt) to which I changed the extension by: ".gnd". I mistakenly deleted the USB folder where I had those files.
When I need to locate specific ".txt" files, in a large database, I usually change the extension name to ".gnd".
Attached I send an example.
Example.rar
(1.01 KiB) Downloaded 482 times
Can you please tell me how to modify this information from photorec.
Thank you.
Re: change name extension ".txt" to ".gnd"
It seems there is no pattern to identify these files except maybe '++++++++++++'...
zagato
#3 Post by zagato »
exactly ... it's a simple "txt" file, but with the extension name ".gnd".
I have the Notepad ++ software, modifying the code in the lines that made reference to "txt" files, I modified it for "gnd" ... but I still can not rescue the files
I appreciate any help.
