I have a Seagate 1TB internal HDD that I use as a storage drive. In the Computer Management app in WIndows 7, it gives onyl the overall size of the drive (931.51 GB) and it is labelled as Unallocated. I do have some important data I would like to save on the disk. It has not had anything else written on the disk since the partition issue occurred. the first test log came up as follows...
The only action I have taken so far was an attempt to put/repair boot sector on the drive because according to Testdisk documentation, it would appear the MBR and Boot Sector need to be repaired/replaced.
More than anything, I would just like to confirm the order of what I am supposed to do to repair the boot sector and mbr. It would appear the software will handle the rest.
thank you for your time!
***** LOG BEGINS *****
Sun Dec 24 13:00:48 2017
TestDisk 7.1-WIP, Data Recovery Utility, November 2017
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=640135028736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdg)=253134635008
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=640135028736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=253134635008
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=640132383744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=253130506240
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000DM003-1ER162, S/N:202020202020202020202020345a305944503956, FW:CC43
Disk /dev/sdb - 640 GB / 596 GiB - CHS 77825 255 63, sector size=512 - WDC WD6400AAKS-00A7B0, S/N:2020202057202d444d5753413059313931363830, FW:01.03B01
Disk /dev/sdg - 253 GB / 235 GiB - CHS 30775 255 63, sector size=512 - Corsair Voyager SliderX1, S/N:0B7F04817020, FW:000A
Disk /dev/sdb - 640 GB / 596 GiB - WDC WD6400AAKS-00A7B0
Analyse Disk /dev/sdb - 640 GB / 596 GiB - CHS 77825 255 63
NTFS at 0/1/1
1 * HPFS - NTFS 0 1 1 77824 254 63 1250258562 [OS Drive]
NTFS at 0/1/1
filesystem size 1250258562
mftmirr_lcn 2
NTFS, blocksize=4096, 640 GB / 596 GiB
file_pread(5,2,buffer,1250265087(77825/102/37)) lseek err Invalid argument
file_pread(5,1,buffer,1250265087(77825/102/37)) lseek err Invalid argument
file_pread(5,2,buffer,1250265088(77825/102/38)) lseek err Invalid argument
file_pread(5,8,buffer,1250263743(77825/81/16)) lseek err Invalid argument
file_pread(5,1,buffer,1250263743(77825/81/16)) lseek err Invalid argument
file_pread(5,8,buffer,1250263871(77825/83/18)) lseek err Invalid argument
file_pread(5,8,buffer,1250263999(77825/85/20)) lseek err Invalid argument
file_pread(5,8,buffer,1250264127(77825/87/22)) lseek err Invalid argument
file_pread(5,8,buffer,1250264255(77825/89/24)) lseek err Invalid argument
file_pread(5,8,buffer,1250264383(77825/91/26)) lseek err Invalid argument
file_pread(5,8,buffer,1250264511(77825/93/28)) lseek err Invalid argument
file_pread(5,8,buffer,1250264639(77825/95/30)) lseek err Invalid argument
file_pread(5,8,buffer,1250264767(77825/97/32)) lseek err Invalid argument
file_pread(5,8,buffer,1250264895(77825/99/34)) lseek err Invalid argument
file_pread(5,8,buffer,1250265023(77825/101/36)) lseek err Invalid argument
file_pread(5,14,buffer,1250265090(77825/102/40)) lseek err Invalid argument
file_pread(5,3,buffer,1250265104(77825/102/54)) lseek err Invalid argument
file_pread(5,3,buffer,1250265151(77825/103/38)) lseek err Invalid argument
file_pread(5,8,buffer,1250265167(77825/103/54)) lseek err Invalid argument
file_pread(5,11,buffer,1250265214(77825/104/38)) lseek err Invalid argument
file_pread(5,2,buffer,1250267136(77825/135/7)) lseek err Invalid argument
Disk /dev/sda - 1000 GB / 931 GiB - ST1000DM003-1ER162
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
FAT32 at 0/32/33
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
no_of_cluster : 98304 (2 - 98305)
fat_length 769 calculated 769
FAT32 at 0/32/33
FAT: cluster=2(0x2), pos=10240
FAT32 0 32 33 12 223 19 204800 [EFI System Partition] [NO NAME]
FAT32, blocksize=1024, 104 MB / 100 MiB
NTFS at 29/49/21
filesystem size 1953054720
mftmirr_lcn 2
HPFS - NTFS 29 49 21 121601 57 56 1953054720
NTFS, blocksize=4096, 999 GB / 931 GiB
file_pread(4,2,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(4,1,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(4,2,buffer,1953525767(121601/90/33)) lseek err Invalid argument
file_pread(4,1,buffer,1953525767(121601/90/33)) lseek err Invalid argument
file_pread(4,2,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(4,1,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(4,2,buffer,1953525830(121601/91/33)) lseek err Invalid argument
file_pread(4,1,buffer,1953525830(121601/91/33)) lseek err Invalid argument
file_pread(4,8,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(4,1,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(4,8,buffer,1953525376(121601/84/20)) lseek err Invalid argument
file_pread(4,8,buffer,1953525504(121601/86/22)) lseek err Invalid argument
file_pread(4,8,buffer,1953525632(121601/88/24)) lseek err Invalid argument
file_pread(4,8,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(4,8,buffer,1953525768(121601/90/34)) lseek err Invalid argument
file_pread(4,3,buffer,1953525776(121601/90/42)) lseek err Invalid argument
file_pread(4,3,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(4,8,buffer,1953525839(121601/91/42)) lseek err Invalid argument
file_pread(4,11,buffer,1953525886(121601/92/26)) lseek err Invalid argument
file_pread(4,2,buffer,1953527808(121601/122/58)) lseek err Invalid argument
* FAT32 0 32 33 12 223 19 204800 [EFI System Partition] [NO NAME]
P HPFS - NTFS 29 49 21 121601 57 56 1953054720
1 * FAT32 0 32 33 12 223 19 204800 [EFI System Partition] [NO NAME]
2 P HPFS - NTFS 29 49 21 121601 57 56 1953054720
First time using TestDisk
Re: First time using TestDisk
Select /dev/hda, choose EFI GPT instead of Intel. If you see all your partitions, choose Write, confirm, Quit and restart your computer.
