Hi Cristophe!
I have a 500 GB external HDD from which I installed Windows 10 to my mother's PC successfully.
'Originally' I created an 8 GB MacOS install drive and the remaining space for music backup formatted HFS+. I reformatted the 8 GB space to NTFS for the Windows 10 installation and from the remained space I created a 100 GB NTFS partition for backup and there were left an almost 400 GB HFS+ formatted space on the HDD where my music is.
Windows Media Creation Tool successfully tarnsformed the whole disk into a 32 GB ESD-USB drive.
I ran TestDisk DeepSearch and the lost 391 GB / 364 GiB HFS+ partition I need is there as a deleted partition. I tried to change the partition from 'D' (deleted) to 'P' (primary) and write the 'changes' but I got write error.
My question is: how to restore this partition to recover the data from.
Waiting for your kind reply.
Krisztián
Of course I have the whole log. I will send it to you if you need it.
Below you can find the relevant part of the log file where you can see the operation I made.
FAT32 LBA 2048 67110911 67108864 [EFI System Partition] [ESD-USB]
FAT32, blocksize=32768, 34 GB / 32 GiB
FAT32 LBA 2054 67110917 67108864 [NO NAME]
HPFS - NTFS 20723 26896 6174
HPFS - NTFS 26896 33069 6174 [Boot]
FAT12 73024 75903 2880 [EFI System Partition] [EFISECTOR]
FAT12 75904 78783 2880 [EFI System Partition] [EFISECTOR]
HFS 409640 765573479 765163840
HFS+ found using backup sector!, 391 GB / 364 GiB
HFS 224376870 224419797 42928
HFS+ found using backup sector!, 21 MB / 20 MiB
HFS 224416436 224459363 42928
HFS 224419794 224462721 42928
HFS+ blocksize=4096, 21 MB / 20 MiB
HFS 224459360 224502287 42928
FAT32 LBA 334097883 599241631 265143749
FAT32 LBA 682467929 801196188 118728260
FAT32 LBA 765835624 960885983 195050360 [100GB]
FAT32, blocksize=32768, 99 GB / 93 GiB
FAT32 LBA 765835630 960885989 195050360 [100GB]
HPFS - NTFS 777837895 778405335 567441
HPFS - NTFS 945785273 961148128 15362856
NTFS found using backup sector, blocksize=4096, 7865 MB / 7501 MiB
HPFS - NTFS 961148128 976510983 15362856 [8GB]
NTFS, blocksize=4096, 7865 MB / 7501 MiB
1 P HFS 409640 765573479 765163840
write!
file_nopwrite(5,1,buffer,0(0/0/1)) write refused
Partition: Write error
Partition lost after using Windows Media Creation Tool
Re: Partition lost after using Windows Media Creation Tool
If you are running testdisk under Mac OS X, you need to umount all partitions from this disk before starting testdisk.
In a Terminal, use 'mount' to get a list of all mounted partitions and for each partition to unmount, run something like "umount /volumes/directory_name"
Hi Christophe!
Thank you for your answer.
Yes, I'm on MacOS. I'll give a try again, but I remember that I unmounted the partitions before write attempt.
Could you help me, how to get to the 'partition-writing-phase' without running a DeepSearch again?
Kind regards,
Krisztián
Kind regards,
Krisztián
