Oke this is my recovery partitions result ---- !!
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
D FAT32 0 32 33 127 155 28 2048000 [ACER_LINUX]
D Linux 129 198 6 31427 134 3 502798336
D Linux Swap 31427 134 4 31932 220 32 8118272
D HPFS - NTFS 31932 220 33 31998 2 4 1046528
>D HPFS - NTFS 31998 67 6 76998 173 39 722931712 -----------> I want to recover this
D HPFS - NTFS 76998 173 40 121601 25 24 716537856 ------------> and this one
Enter: to continue
NTFS, blocksize=4096, 370 GB / 344 GiB
so when i set from D to L i got Structure : bad .. so what should i do .. ??
L HPFS - NTFS 31998 67 6 76998 173 39 722931712
>L HPFS - NTFS 76998 173 40 121601 25 24 716537856
Structure: Bad. Use Up/Down Arrow keys to select partition.
Enter: to continue
NTFS, blocksize=4096, 366 GB / 341 GiB
I read the instruction like this ..
"Using the left/right arrow keys, change the status of the selected partition from D(eleted) to L(ogical). This way you will be able to recover this partition"
but if i chose P for both ( partitions that i want to recover ) the structure status is : ok
should be i use P .. Please give me solutions i really need my data back !! thanks
What Should I do , I have Strukture : bad status .. !!
Re: What Should I do , I have Strukture : bad status .. !!
Unfortunately you didn't provide the testdisk.log file. We don't know how your partition table is currently.
The correct partition table type may be EFI GPT and not PC Intel.
cgrenier wrote: 06 Jan 2018, 09:55 Unfortunately you didn't provide the testdisk.log file. We don't know how your partition table is currently.
Sat Jan 6 09:10:22 2018
OS: Linux, kernel 4.9.0-kali3-amd64 (#1 SMP Debian 4.9.18-1kali1 (2017-04-04)) x86_64
Compiler: GCC 6.2
ext2fs lib: 1.43.4, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.0
/dev/sda: size 1953525168 sectors
/dev/sda: user_max 1953525168 sectors
/dev/sda: native_max 1953525168 sectors
/dev/sda: dco 1953525168 sectors
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - TOSHIBA MQ01ABD100, S/N:Y6GRCBW2T, FW:AX1P5J
Disk /dev/sdb - 7775 MB / 7415 MiB - CHS 1020 240 62, sector size=512 - ADATA USB Flash Drive, FW:0.00
Disk /dev/sda - 1000 GB / 931 GiB - TOSHIBA MQ01ABD100
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
BAD_RS LBA=1 0
1 P EFI GPT 0 0 2 121601 80 63 1953525167
Bad relative sector.
FAT32 at 0/32/33
FAT1 : 4206-6198
FAT2 : 6199-8191
Data : 8192-2047999
sectors : 2048000
cluster_size : 8
no_of_cluster : 254976 (2 - 254977)
fat_length 1993 calculated 1993
FAT32 at 0/32/33
FAT32, blocksize=4096, 1048 MB / 1000 MiB
recover_EXT2: s_block_group_nr=0/1918, s_mnt_count=4/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 62849792
recover_EXT2: part_size 502798336
ext4 blocksize=4096 Large_file Sparse_SB, 257 GB / 239 GiB
Linux Swap 31427 134 4 31932 220 16 8118256
SWAP2 version 1, pagesize=4096, 4156 MB / 3963 MiB
NTFS at 31932/220/33
filesystem size 1046528
mft_lcn 43605
mftmirr_lcn 2
NTFS, blocksize=4096, 535 MB / 511 MiB
NTFS at 31998/67/6
filesystem size 722931712
mftmirr_lcn 2
NTFS at 76998/173/40
filesystem size 716537856
mftmirr_lcn 2
SWAP2 version 1, pagesize=4096, 4156 MB / 3964 MiB
Hint for advanced users. dmsetup may be used if you prefer to avoid to rewrite the partition table for the moment:
echo "0 2048000 linear /dev/sda 2048" | dmsetup create test0
echo "0 502798336 linear /dev/sda 2084864" | dmsetup create test1
echo "0 8118272 linear /dev/sda 504883200" | dmsetup create test2
echo "0 1046528 linear /dev/sda 513001472" | dmsetup create test3
echo "0 722931712 linear /dev/sda 514052096" | dmsetup create test4
echo "0 716537856 linear /dev/sda 1236983808" | dmsetup create test5
