after format no files found on disk?
Tommy19r
#1 Post by Tommy19r »
Hello:
I did a Format and then a quick format. mostly jpg and mp4. Now I tried test disk and photoreq but no files found at all . nothing? did i miss something?
thank you
Re: after format no files found on disk?
Run PhotoRec. In Options, enable the expert mode, start the recovery, when asked, choose a blocksize of 512, use the default values otherwise.
Please tell us if you recover your data this way.
Tommy19r
#3 Post by Tommy19r »
yes i was able to follow your instructions and .....after 10 minutes I stopped. Nothing. no files.
Thank you.
Is it an SSD with TRIM enabled ? If it's the case, it can explain why no files have been recovered.
Tommy19r
#5 Post by Tommy19r »
yes it is external SSD and Trim was enabled. recovery options possible?
Thank you.
#6 Post by cgrenier »
None unfortunately.
