I have hopefully a simple question, I've been able to locate my files, however I'm still having some issues booting the drive. But while i'm in here I do want to try and copy onto some other drives I have (that it is recognizing). I have a couple fat32 thumb drives that it shows in the list but not sure how to navigate to them. I'm using a copy that's built into UBCD and Parted Magic.
Thanks!
How to copy selected files on to a different partition/disk
tbell45219
Re: How to copy selected files on to a different partition/disk
When asked for the destination, use the left arrow key until you have a list of drives. You should be able to select the destination you want.
