Hello
my SDD got corupted, Win10 does not boot any longer.
I have no clue what should be the next step to solve the problem, many Thanks for your help!!!!
I run testdisk here the log:
Wed Jan 17 23:21:59 2018
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=1050214588416
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdj)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=1050214588416
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=3000592982016
filewin32_getfilesize(\\.\PhysicalDrive4) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\PhysicalDrive4) SetFilePointer err Unzulässige Funktion.
filewin32_getfilesize(\\.\PhysicalDrive5) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\PhysicalDrive5) SetFilePointer err Unzulässige Funktion.
filewin32_getfilesize(\\.\PhysicalDrive6) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\PhysicalDrive6) SetFilePointer err Unzulässige Funktion.
filewin32_getfilesize(\\.\PhysicalDrive7) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\PhysicalDrive7) SetFilePointer err Unzulässige Funktion.
filewin32_getfilesize(\\.\PhysicalDrive8) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\PhysicalDrive8) SetFilePointer err Unzulässige Funktion.
Warning: can't get size for \\.\PhysicalDrive8
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive9)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1049569001472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2000263577600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=3000457232384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=249347178496
Disk /dev/sda - 1050 GB / 978 GiB - CHS 127681 255 63, sector size=512
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Disk /dev/sdc - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512
Disk /dev/sdj - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512
Drive C: - 1049 GB / 977 GiB - CHS 127602 255 63, sector size=512
Drive D: - 2000 GB / 1862 GiB - CHS 243184 255 63, sector size=512
Drive F: - 3000 GB / 2794 GiB - CHS 364784 255 63, sector size=512
Drive M: - 249 GB / 232 GiB - CHS 30314 255 63, sector size=512
Analyse Drive M: - 249 GB / 232 GiB - CHS 30314 255 63
Geometry from i386 MBR: head=106 sector=52
BAD_RS LBA=1380404564 216152
check_part_i386 1 type 0A: no test
BAD_RS LBA=1309281536 5870947
check_part_i386 2 type 69: no test
BAD_RS LBA=1735554131 4633953
check_part_i386 3 type 6D: no test
BAD_RS LBA=2978742282 5980572
check_part_i386 4 type 66: no test
1 * OS/2 Boot Manager 85926 53 36 200213 18 49 1836018464
2 * Novell 81499 1 39 203112 174 43 1953723749
Bad relative sector.
3 * Sys=6D 108033 63 18 229617 137 22 1953251627
4 * Sys=66 185418 33 34 185421 145 15 55233
BAD_RS LBA=1278325504 5701782
FAT32 79572 21 2 146431 234 46 1074103299
This partition ends after the disk limits. (start=1278325504, size=1074103299, end=2352428802, disk end=487006208)
file_win32_pread(616,1,buffer,487006207(30314/187/17)) read err: read after end of file
The harddisk (249 GB / 232 GiB) seems too small! (< 1204 GB / 1121 GiB)
interface_load
New options :
Dump : No
Align partition: Yes
Expert mode : No
SSD can't boot Win10, can't read FAT boot sector
Re: SSD can't boot Win10, can't read FAT boot sector
It's useless to search for partitions inside a partition.
Start by checking the filesystems, read https://www.cgsecurity.org/testdisk.pdf
