When I first used PhotoRec the TXT files opened normally.
Now they open like the below.
I changed the default app and that did not open the txt files normally.
When I open a folder with the file images they appear normal then a second later they change to the source code format below or whatever that is:
0004"
stCamera:RadialDistortParam1="-0.000534"
stCamera:RadialDistortParam2="0.002953"
stCamera:RadialDistortParam3="-0.003368"/>
<stCamera:VignetteModel
stCamera:ResidualMeanError="0.000451"
stCamera:VignetteModelParam1="-0.375869"
stCamera:VignetteModelParam2="0.121616"
stCamera:VignetteModelParam3="0.169687"/>
</rdf:Description>
</stCamera:PerspectiveModel>
</rdf:Description>
</rdf:li>
<rdf:li>
<rdf:Description
stCamera:Author="Adobe (www.adobe.com)"
stCamera:Make="PENTAX"
stCamera:CameraRawProfile="True"
stCamera:LensID="8 232"
stCamera:Lens="smc PENTAX-DA 17-70mm F4 AL [IF] SDM"
stCamera:LensInfo="170/10 700/10 40/10 40/10"
stCamera:CameraPrettyName="PENTAX"
stCamera:LensPrettyName="smc PENTAX-DA 17-70mm F4 AL [IF] SDM"
stCamera:ProfileName="Adobe (smc PENTAX-DA 17-70mm F4 AL [IF] SDM)"
stCamera:SensorFormatFactor="1.5"
stCamera:FocalLength="17"
stCamera:FocusDistance="1.68"
stCamera:ApertureValue="8">
<stCamera:PerspectiveModel>
<rdf:Description
stCamera:Version="2"
stCamera:ResidualMeanError="0.000032"
stCamera:ResidualStandardDeviation="0.000023"
stCamera:RadialDistortParam1="-0.103669"
stCamera:RadialDistortParam2="0.033312"
stCamera:RadialDistortParam3="0.03727">
<stCamera:ChromaticRedGreenModel
stCamera:ResidualMeanError="0.000001"
stCamera:ResidualStandardDeviation="0"
stCamera:ScaleFactor="1.00038"
stCamera:RadialDistortParam1="0.000441"
stCamera:RadialDistortParam2="-0.002227"
stCamera:RadialDistortParam3="0.002388"/>
<stCamera:ChromaticGreenModel
stCamera:RadialDistortParam3="0.03727"/>
<stCamera:ChromaticBlueGreenModel
stCamera:ResidualStandardDeviation="0.000001"
stCamera:ScaleFactor="1.000365"
stCamera:RadialDistortParam1="-0.000547"
stCamera:RadialDistortParam2="0.002966"
stCamera:RadialDistortParam3="-0.003396"/>
stCamera:ResidualMeanError="0.000458"
stCamera:VignetteModelParam1="-0.372593"
stCamera:VignetteModelParam2="0.123775"
stCamera:VignetteModelParam3="0.166759"/>
</rdf:Description>
</rdf:Description>
</rdf:li>
<rdf:li>
<rdf:Description
stCamera:FocusDistance="10000000000"
<rdf:Description
stCamera:ResidualStandardDeviation="0.000024"
stCamera:RadialDistortParam1="-0.100299"
stCamera:RadialDistortParam2="0.035726"
stCamera:RadialDistortParam3="0.035954">
stCamera:ScaleFactor="1.000434"
stCamera:RadialDistortParam1="0.000454"
stCamera:RadialDistortParam2="-0.002241"
stCamera:RadialDistortParam3="0.002422"/>
stCamera:RadialDistortParam3="0.035954"/>
stCamera:ScaleFactor="1.000288"
stCamera:RadialDistortParam2="0.00284"
stCamera:RadialDistortParam3="-0.003306"/>
stCamera:ResidualMeanError="0.00043"
stCamera:VignetteModelParam1="-0.366229"
stCamera:VignetteModelParam2="0.13454"
stCamera:VignetteModelParam3="0.151893"/>
</rdf:Description>
</rdf:Description>
</rdf:li>
<rdf:li>
Please help.
Thank you,
Chris
Re: I changed the default app and that did not open the txt files normally.
Do you have this problem with latest 7.1-WIP ?
In PhotoRec, disable txt and tx? file family in FileOpts and try again a data recovery. Do you get better results ?
Hi Chris,
I am using the most recent download from your site for OSX. I have OSX 10.11.6
I am trying to get .doc and docx files.
I will disable txt and tx but then how do I get the doc and docx files?
Thank you,
Chris
Thank you,
Chris
I just checked doc files and will try that.
