TestDisk finds no partition and lots of read errors on WD MyPassport 1TB
moconnell
#1 Post by moconnell »
I have a WD My Passport 1TB USB drive which used to be un-encrypted with a lot of photo backups on it. Now it always prompts for a password which we never set up.
I suspect the main partition information is missing somehow, and as a fallback shows the other partition with WD's security software on it.
I was recommended to try TestDisk, and I let is to a deep scan but it found no partition information and gave lots of read errors. Here is the last few from the log:
file_pread(6,11,buffer,651454(318/5/31)) read err: Input/output error
file_pread(6,2,buffer,653376(319/2/1)) read err: Input/output error
file_pread(6,1,buffer,653311(318/63/32)) read err: Input/output error
file_pread(6,14,buffer,653314(319/0/3)) read err: Input/output error
file_pread(6,3,buffer,653328(319/0/17)) read err: Input/output error
file_pread(6,3,buffer,653375(319/1/32)) read err: Input/output error
file_pread(6,8,buffer,653391(319/2/16)) read err: Input/output error
file_pread(6,11,buffer,653438(319/3/31)) read err: Input/output error
file_pread(6,2,buffer,655360(320/0/1)) read err: Input/output error
file_pread(6,1,buffer,1953456127(953835/63/32)) read err: Input/output error
file_pread(6,1,buffer,1953456128(953836/0/1)) read err: Input/output error
file_pread(6,14,buffer,1953456129(953836/0/2)) read err: Input/output error
file_pread(6,3,buffer,1953456143(953836/0/16)) read err: Input/output error
file_pread(6,3,buffer,1953456190(953836/1/31)) read err: Input/output error
file_pread(6,8,buffer,1953456206(953836/2/15)) read err: Input/output error
file_pread(6,11,buffer,1953456253(953836/3/30)) read err: Input/output error
What do you guys recommend I try next?
Re: TestDisk finds no partition and lots of read errors on WD MyPassport 1TB
Contact WD, it's probably a know problem, they may have a solution.
