Hi
Sorry for barely knowing what Im doing but need help please!
I'm attaching test disk output below.
I have an external 2GB disk. This disk used to have 1.5GB Nac OSX time machine backup (encrypted) Partition and a 500 GB Windows NT partition.
I used this disk for months no problems. OSX was backing fine and I could access the NT partition whenever i needed.
1 month ago I decided to delete the Wndows NT partition in order to expand the OSX time machine partition.
( i can not recall what program i used but it was a free windows program, possibly EaseUS or Minitool )
After deletion of the NT partition the disk is NO longer usable. Keeps showing up Un-partitioned in OSX and Windows.
The deep scan output below seems to show only the NT partition is recoverable.
COULD SOMEONE PLS TEL ME HOW I SHUOLD PROCEED TO RECVOER THE OSX Time Machine backups or partition.
(PS once the OSX partition is recovered i plan to use Gnu parted to expand the OSX partition, unless another program is recommended)
TestDisk 7.1-WIP, Data Recovery Utility, January 2018
Disk /dev/disk2 - 2000 GB / 1863 GiB - 3907029167 sectors
>P EFI System 40 409639 409600 [EFI System Partition]
D MS Data 1959772313 2933269648 973497336
D Linux filesys. data 2759907509 2766837402 6929894 [M~Bl1 ^F 8| t]
D Mac HFS 2933007504 2933269647 262144
D MS Data 2933269648 3906766983 973497336 [Win-Bakup]
P Mac HFS 3906766984 3907029127 262144..
P=Primary D=Deleted
Enter: to continue
URGENT: newbie needs help mixed partitions OSX +NT
Re: URGENT: newbie needs help mixed partitions OSX +NT
If your HFS+ partition isn't listed, try Deeper Search.
Please copy and paste the whole testdisk.log.
Firstly, Thank you very much!
there is no "deeper search" option available at this screen...? I believe it already did it since it took 21 hours ?
BTW below are screen shots of disk as seen by Gparted, the problem (required) partition is the 1.37TB (/dev/sdb2) where the HFS partition should be.
https://drive.google.com/file/d/1wGkIDp ... sp=sharing
https://drive.google.com/file/d/14ncD8c ... sp=sharing
and the log file , ps i have run it a added to the log a couple of times so you may wanna look at the latest time stamps--
Tue Jan 16 16:51:25 2018
OS: Darwin, kernel 17.3.0 (Darwin Kernel Version 17.3.0: Thu Nov 9 18:09:22 PST 2017; root:xnu-4570.3
Compiler: GCC 4.0
Compilation date: 2018-01-08T19:00:18
Disk /dev/disk2 - 2000 GB / 1863 GiB - 3907029167 sectors, sector size=512
Disk /dev/rdisk2 - 2000 GB / 1863 GiB - 3907029167 sectors, sector size=512
Partition table type: EFI GPT
Analyse Disk /dev/rdisk2 - 2000 GB / 1863 GiB - 3907029167 sectors
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=3907029166 (expected 3907029166)
hdr_lba_start=34
hdr_lba_end=3907029133
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P EFI System 40 409639 409600 [EF]
2 P Windows Recovery Env 409640 2933007503 2932597864 [Ol]
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
sect/track 32 (FAT) != 1 (HD)
FAT32 at 40/0/1
EFI System 40 409639 409600 [EFI System Partition] [EFI]
LVM magic value at 14260281/0/1
P EFI System 40 409639 409600 [EFI System Partition] [EFI]
gpt_change_part_type
SIGINT detected! TestDisk has been killed.
Tue Jan 16 18:14:46 2018
Compiler: GCC 4.0
Analyse Disk /dev/disk2 - 2000 GB / 1863 GiB - 3907029167 sectors
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
LVM magic value at 967539093/0/1
SYSV4 Marker at 2735697731/0/1
recover_sysv4
Unknown 2735697731 2735697730 0 [\Dµa{]
SysV4, 0 B
Partition not added.
cramfs Marker at 2759907509/0/1
recover_cramfs
Linux filesys. data 2759907509 2766837402 6929893 [Ml1ºé¼Dîd¡8|¨t]
cramfs, 3548 MB / 3383 MiB
Unknown 2841266873 5005641195866808 5005638354599936
WBFS, 2562886 TB / 2330932 TiB
HFS+ magic value at 2933007504/0/1
part_size 262144
HFS+ blocksize=4096 + Backup, 134 MB / 128 MiB
NTFS at 2933269648/0/1
filesystem size 973497336
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 498 GB / 464 GiB
mftmirr_lcn 2
NTFS, blocksize=4096, 498 GB / 464 GiB
HFS+ magic value at 3906766984/0/1
part_size 262144
Linux filesys. data 2759907509 2766837402 6929894 [Ml1ºé¼Dîd¡8|¨t]
Change partition type:
Mac HFS 1 3907029166 3907029166
Unknown 1 3907029166 3907029166
HFS+ 1 3907029166 3907029166
Invalid partition structure.
Wed Jan 17 22:35:01 2018
Compiler: GCC 4.0
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
1 P EFI System 40 409639 409600 [EFI System Partition] [EFI]
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
Backup partition structure
partition_save
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
recover_sysv4
SysV4, 0 B
recover_cramfs
part_size 262144
mftmirr_lcn 2
mftmirr_lcn 2
part_size 262144
EFI System 1 3907029166 3907029166
MS Data 1 3907029166 3907029166
NTFS 1 3907029166 3907029166
P HFS+ 3906766984 3907029127 262144
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
New options :
Dump : No
Align partition: Yes
Expert mode : No
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
2 P Mac HFS 409640 2933007503 2932597864 [Ol]
2 P HFS+ 409640 2933007503 2932597864 [Ol]
HFS_HFSP_boot_sector
Volume header
Bad
Backup volume header
Bad
Sectors are not identical.
Volume header
Bad
Bad
1 P Mac HFS 40 409639 409600 [EF]
1 P HFS+ 40 409639 409600 [EF]
Volume header
Bad
Bad
Sectors are identical.
Sun Jan 28 03:33:33 2018
Compiler: GCC 4.0
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
FAT32 at 46/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 46/0/1
EFI System 46 409645 409600 [EFI System Partition] [EFI]
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
recover_sysv4
SysV4, 0 B
recover_cramfs
part_size 262144
mftmirr_lcn 2
mftmirr_lcn 2
part_size 262144
2 P Mac HFS 3906766984 3907029127 262144
Compiler: GCC 4.0
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
Compiler: GCC 4.0
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
recover_sysv4
SysV4, 0 B
recover_cramfs
part_size 262144
mftmirr_lcn 2
mftmirr_lcn 2
part_size 262144
Compiler: GCC 4.0
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
partition_save
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
recover_sysv4
SysV4, 0 B
recover_cramfs
part_size 262144
mftmirr_lcn 2
mftmirr_lcn 2
part_size 262144
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
New options :
Dump : No
Expert mode : No
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
Volume header
Bad
Bad
Volume header
Bad
Bad
Volume header
Bad
Bad
Compiler: GCC 4.0
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
FAT32 at 46/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 46/0/1
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
recover_sysv4
SysV4, 0 B
recover_cramfs
part_size 262144
mftmirr_lcn 2
mftmirr_lcn 2
part_size 262144
There is more than 1 TB for your missing partition after the EFI partition and before the NTFS filesystem.
I don't know why no partition is detected. Try other data recovery utilities...
OK Thanks, trying EaseUS Data Recovery -any util in particular you might suggest?
