can this be done? (rebuild raid 0 windows disk?)
Deleted User 9999
#1 Post by Deleted User 9999 »
whelp, the unthinkable happened. After years of running a raid 0 system disk, I had an issue which resulted in me swapping to my dual bios and changing sata ports.
this caused the failure of one of my raid0 ssds. I put it back and flipped the dipswitch to the original bios but to no avail. The disk showed as failed there as well.
I got so far as removing the remaining disk from the array, and creating a new array with the same stripe size.
however best i can tell, this utility requires being in windows to run? Does this leave me SOL?
thank you for your time and help!
Re: can this be done? (rebuild raid 0 windows disk?)
After recreating your RAID, you may have to recreate your partition table.
You can start testdisk from a Linux USB key if necessary, see https://www.cgsecurity.org/testdisk.pdf
Running PhotoRec during a few minutes may help you to find if your Raid0 setup is correct, if it's ok, you will get a lot of valid files, if it's wrong, only small or invalid files.
