TestDisk time
TestDisk time
Hello, I am currently running Undelete on a 64GB microSD card. I started the process over 5 hours ago. My recovery folder (the copy destination) shows 49GB of data and 1300 files, but nothing is actually in it. Is it normal for the process to take this long? And is there any way to estimate how much longer it will be? Attached is a screenshot of the command prompt.
- testdisk.png (15.39 KiB) Viewed 4059 times
Re: TestDisk time
You wrote
TestDisk shows a very high number of failed copies, I don't know why.
It may be faster to run PhotoRec but it doesn't recover the original filenames.
There is probably a subfolder named "Album 1".My recovery folder (the copy destination) shows 49GB of data and 1300 files, but nothing is actually in it.
