Hi Everyone,
I know this story sounds the same as everyone else and I have searched but I cannot seem to find how to fix my problem:
I erased a partition using disk utility on my mac thinking I had a backup of it.
I tried using test disk for over a week now and I still can't figure it out.
I even tried the suggestion of Repair a Mac OS X HFS+ Partition table and then ran test disk again.
I un mounted all partitions and I am trying the disc image copy option (the erased partition) to an external. Is this correct?
I don't see the following menu from another post.
run TestDisk, Advanced, Boot, RebuildBS, List and if you can see your files, choose Write, confirm
When I click advanced, there is no "Boot" option
Thank you in advance
jon
Erased partition on Mac using disk utility by mistake
Re: Erased partition on Mac using disk utility by mistake
"Advanced, Boot, RebuildBS" is to repair FAT, exFAT or NTFS filesystem, for HFS+, it's Superblock, but from your problem description, you are not in the case of damaged filesystem.
If it's a problem of deleted partition, TestDisk should recover it after Analyse, Quick Search and if necessary Deeper Search.
If the partition has been reformated, use PhotoRec.
Hi jwpcxs,
Could you resolve the incident?. I have the same problem but could not recover my lost partition.
Please tell me if you resolve and how.
Thanks in advance.
Thanks in advance.
