hello,
I have recovered many files thanks to photorec, but I can't open those with the extension prproj. When I try to open them, it gives me an error. Does anyone know what I could do to recover them?
thanks
Problem recovery .prproj files (Adobe premiere )
Re: Problem recovery .prproj files (Adobe premiere )
The problem may be a truncated file or a file with garbage at the end. You should be able to edit with wordpad.
You should be able to edit with wordpad.I found some garbage in the files, but can't correct it.
