Can't access files on SD-Card
anbaum
#1 Post by anbaum »
Hello!
I posted in the German part of the forum, but since there hasn’t been an answer yet... Apart from that: Sorry for my English!
I am having a problem with a 32GB SDHC card (from Transcend), where I can no longer access the (mostly) image files stored on it. By Photorec and with the help of this ingenious forum, I could already save a large part of the photos, but it lacks so far still the last taken pictures, which are unfortunately most important (it is the memory card of our school camera). I am an absolute amateur concerning data recovery etc., so I would be very grateful for any help!
I try to give as much information as possible on the problem:
1. Camera (Sony Alpha 5) and Windows (Translations from the German text: "You must be able to format the disk in drive F before you can use it" and "F: \ can not be accessed. There is no detected file system on the disk...”) can not access the files.
2. As far as I know, partitions are not created on the memory card.
3. Programs like Recuva can’t access the card.
4. Photorec was able to recover images, but not all (the most recent ones are still missing).
5. Chkdsk reports "The file system type is RAW." and can’t access it.
6. At Testdisk I have tried the following with instructions from various forum posts (unfortunately usually without really knowing what I'm doing there):
- Analysis with setting partition table type "none" did not find any partitions and with the setting "Intel" it said "Partition sector does not have the endmark 0xAA55"
- for the item Advanced and the setting partition table "none", type "ntfs" the message "Boot sector Status: Bad, Backup boot sector Status: Bad, Sectors are identical. A valid NTFS Boot sector must be present in order to access any data; even if the partition is not bootable." was displayed
- at the item Advanced and the setting partition table "none", type "Fat32" the message "Boot sector Bad, Backup boot sector Bad, First sectors (Boot code and partition information) are not identical. Second sectors (cluster information) are not identical. Third sectors (Second part of boot code) are not identical. A valid FAT Boot sector must be present in order to access any data; even if the partition is not bootable." showed up
More I do not trust myself without expert guidance (wich is probably better that way too ...)
I attach the testdisk log file, maybe it gives even more insights.
Thank you for all attempts to help !!!
Best regards
Andreas
Testdisk-Log-File:
Wed Mar 14 15:56:25 2018
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=128035676160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=32504807424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=32504807424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=113472700416
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=32500613120
Disk /dev/sda - 128 GB / 119 GiB - CHS 15566 255 63, sector size=512
Disk /dev/sdc - 32 GB / 30 GiB - CHS 3951 255 63, sector size=512
Drive C: - 113 GB / 105 GiB - CHS 13795 255 63, sector size=512
Drive D: - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512
Drive F: - 32 GB / 30 GiB - CHS 3951 255 63, sector size=512
Partition table type: None
Analyse Drive F: - 32 GB / 30 GiB - CHS 3951 255 63
P Unknown 0 0 1 3951 78 31 63477760
Store new MBR code
Change partition type:
P NTFS 0 0 1 3951 78 31 63477760
ntfs_boot_sector
filesystem size 1
sectors_per_cluster 0
mft_lcn 268435567
mftmirr_lcn 0
clusters_per_mft_record 0
clusters_per_index_record 0
Status: Bad
Status: Bad
ntfs_boot_sector
filesystem size 1
mft_lcn 268435567
mftmirr_lcn 0
Status: Bad
Status: Bad
P FAT32 0 0 1 3951 78 31 63477760
fat32_boot_sector
Bad
Bad
