adobe xd file format recovery
martschy
#1 Post by martschy »
Hi there,
I accidently forgot one file to add to a backup before formating a disk :shock:
the file is an adobe xd file with the extension .xd
and the signature checker https://www.cgsecurity.org/photorec/ says
PhotoRec has recovered:
f0000000.sxw - size=13124
WARNING: extension doesn't match - recovered file:sxw - original: xd
https://www.cgsecurity.org/photorec/sca ... faa3fc14bf
as .sxw is an 'OpenOffice Text Document (ZIP archive)' the extension does not match I guess.
so would photorec be able to recover that file as an .sxw file or would it be broken or not recoverable?
Thank you for any help :)
Re: adobe xd file format recovery
I have uploaded a new 7.1-WIP version. Can you try it ?
