Help: diskpart "cleaned" fat32 partition
frankk74
#1 Post by frankk74 »
FYI... using diskpart and a drive goes offline it chooses or uses the device before it....without warning you
I mistakenly *thank you diskpart" "cleaned" a 250gb external drive. A sd card driver letter after the got popped out.. diskpart was configured to clean that drive but picked up the drive before ...
I have tried the following TestDisk(linux and windows),gparted, gnome disk and Minitool Partition Recovery V7.5...
Initially, Minitool found the 220GB of files so I didn't use it. The I tried various tools then ran it again and it only found 120GB of files...
Unfortunately the filesystem/partition had 2 ~30GB linux filesystems (raspberry pi) images had the tools (mainly gparted/gpart) mistakenly found those..
I have tried to attach the log files from TestDisk and minitool...
I suspect that the data is mostly gone now... but I was hoping it could be used to "enhance" testdisk because mintool still finds files and linux still finds the partition (or 2 of them being the same)..
Te following are some datapoints:
- exFAT filesystem on Samsung T3 external SSD 250GB, exFAT support might be part of the problem
- Linux reports 2 fat partitions but with the same info same size etc.. so that is probably messing up things
- other error messages are:
- Partition sector doesn't have the endmark 0xAA55,Invalid FAT boot sector (TestDisk messages)
- fsck.fat logical sector size is zero
This forum software is not allowing me to attached the logfiles.. invalid file type (extensions none, .txt, .log)
Help... Please and thank you...!!!!!
Frank
Re: Help: diskpart "cleaned" fat32 partition
Please copy and paste the testdisk.log file content
frankk74
#3 Post by frankk74 »
Linux log file:
Mon Mar 19 18:57:33 2018
Command line: TestDisk /log /dev/sdc1
TestDisk 7.1-WIP, Data Recovery Utility, March 2018
OS: Linux, kernel 4.15.7-300.fc27.x86_64 (#1 SMP Wed Feb 28 17:53:39 UTC 2018) x86_64
Compiler: GCC 4.4
ext2fs lib: 1.42.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504, curses lib: ncurses 5.7
Disk /dev/sdc1 - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung Portable SSD T3
Disk /dev/sdc1 - 250 GB / 232 GiB - Samsung Portable SSD T3
Analyse Disk /dev/sdc1 - 250 GB / 232 GiB - CHS 30401 255 63
Filesystem created: Thu Sep 21 09:13:04 2017
Last mount time: Mon Nov 6 15:12:48 2017
Linux 23688 22 15 25617 53 36 30991360 [retropie]
ext4 blocksize=4096 Large_file Sparse_SB Recover, 15 GB / 14 GiB
1 * Linux 23688 22 15 25617 69 52 30992384 [retropie]
Using locale 'en_CA.UTF-8'.
Mon Mar 19 19:02:42 2018
Compiler: GCC 4.4
Disk /dev/sdc - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung Portable SSD T3
Disk /dev/sdc - 250 GB / 232 GiB - Samsung Portable SSD T3
Analyse Disk /dev/sdc - 250 GB / 232 GiB - CHS 30401 255 63
1 P FAT32 LBA 0 32 33 30401 42 41 488392704
frankk74
#4 Post by frankk74 »
Windows log file:
un Mar 18 21:44:59 2018
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=127139840
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=127139840
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=246698634752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=127139840
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung SSD 840 EVO 250GB, S/N:S1DBNSADC79975J, FW:EXT0BB0Q
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10JPVX-22JC3T0, S/N:WD-WXF1AA501KYE, FW:01.01A01
Disk /dev/sdc - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung Portable SSD T3, S/N:CC2B97654321
Disk /dev/sdd - 127 MB / 121 MiB - CHS 15 255 63, sector size=512 - RICOH R5C822, S/N:0001, FW:01
test_FAT()
1 P FAT16 >32M 0 32 33 30401 42 41 488392704
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
recover_EXT2: s_block_group_nr=0/118, s_mnt_count=152/4294967295, s_blocks_per_group=32768, s_inodes_per_group=7840
recover_EXT2: s_blocks_count 3873920
recover_EXT2: part_size 30991360
Linux 23688 54 47 25617 86 5 30991360 [retropie]
file_pread(6,2,buffer,488398847(30401/107/42)) lseek err Invalid argument
file_pread(6,1,buffer,488398847(30401/107/42)) lseek err Invalid argument
file_pread(6,2,buffer,488398848(30401/107/43)) lseek err Invalid argument
file_pread(6,14,buffer,488398850(30401/107/45)) lseek err Invalid argument
file_pread(6,3,buffer,488398864(30401/107/59)) lseek err Invalid argument
file_pread(6,3,buffer,488398911(30401/108/43)) lseek err Invalid argument
file_pread(6,8,buffer,488398927(30401/108/59)) lseek err Invalid argument
file_pread(6,11,buffer,488398974(30401/109/43)) lseek err Invalid argument
file_pread(6,2,buffer,488400896(30401/140/12)) lseek err Invalid argument
* Linux 23688 54 47 25617 102 21 30992384 [retropie]
1 * Linux 23688 54 47 25617 102 21 30992384 [retropie]
recover_EXT2: s_block_group_nr=0/118, s_mnt_count=147/4294967295, s_blocks_per_group=32768, s_inodes_per_group=7840
Last mount time: Mon Nov 6 13:30:23 2017
Linux 23688 152 17 25617 183 38 30991360 [retropie]
recover_EXT2: s_block_group_nr=0/118, s_mnt_count=10/4294967295, s_blocks_per_group=32768, s_inodes_per_group=7840
Last mount time: Thu Oct 5 13:29:45 2017
Linux 23695 122 44 25624 154 2 30991360 [retropie]
Linux 23688 152 17 25617 199 54 30992384 [retropie]
Linux 23695 122 44 25624 170 18 30992384 [retropie]
test_FAT()
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
test_FAT()
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
FAT: Can't list files, bad cluster size.
Sun Mar 18 22:25:03 2018
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=250057064448
test_FAT()
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
New options :
Dump : No
Align partition: Yes
Expert mode : Yes
test_FAT()
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
frankk74
#5 Post by frankk74 »
Looks like I had a bad usb port which triggered the whole mess.
I suspect the drive/filesystem was messed up by that.
Thank you!
Frank
