hope you can help:
I have 2 x 3 TB hdd in a Raid 0; external (/dev/sda). I had 2 partitions on it: 1: 2 TB NTFS and 2: 4 TB NTFS. The 4 TB is encrypted by VeraCrypt. Few days ago this RAID showd up in Win 7 as a single unallocated disk that wanted to be initialized. I did not touch it but tried to recover the partitions with TestDisk.
TestDisk found the Raid, I made a backup of the current partitions structure and run Quick Search. It found 2 partitions that I meant to be correct and wrote that structure. But the written structure turns out to be not correct. (I did not care about: "The harddisk seems too small")
What can I do ?
Is it possible:
1) get back to the beginning by loading the backup.log?
2) if 1) should work can I "cut" the size of partition 2 in order that it fits to the disk? (Partition 1 seems to be fine... I see my files in it)
Hope you can help.
Best Regards
Mike
The log:
Tue Mar 27 16:39:30 2018
TestDisk 7.1-WIP, Data Recovery Utility, March 2018
Compiler: GCC 6.4, Cygwin32 2009.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=6001185947648
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=5999999975424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=3000469553152
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=6001185947648
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=5999999975424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=3000469553152
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=104847611392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=41948927488
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=41940671488
filewin32_getfilesize(\\.\F:) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\F:) SetFilePointer err Unzulässige Funktion.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=1887436800000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=693467034624
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\U:)=104857600000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\V:)=314571751424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Z:)=5999863529472
Disk /dev/sda - 6001 GB / 5589 GiB - CHS 729602 255 63, sector size=512 - JMB352 RAID-0, S/N:2020202057202d4443573443364e564b46353845
Disk /dev/sdb - 512 GB / 476 GiB - CHS 62260 255 63, sector size=512 - Samsung SSD 850 PRO 512G, S/N:S2BENWAJ610401R, FW:EXM0
Disk /dev/sdc - 5999 GB / 5587 GiB - CHS 729458 255 63, sector size=512 - AMD 2+0 Stripe/RAID0, S/N:2503bc080000000000000000000000000000000000000000, FW:1.10
Disk /dev/sdd - 3000 GB / 2794 GiB - CHS 182393 255 63, sector size=1024 - AMD 2+0 Stripe/RAID0, S/N:d4ea1e5ac3ac000000000000000000000000000000000000, FW:1.10
Disk \\.\PhysicalDrive3 - 3000 GB / 2794 GiB - CHS 182393 255 63, sector size=1024 - AMD 2+0 Stripe/RAID0, S/N:d4ea1e5ac3ac000000000000000000000000000000000000, FW:1.10
Drive G: - 1887 GB / 1757 GiB - CHS 114733 255 63, sector size=1024 - AMD 2+0 Stripe/RAID0, S/N:d4ea1e5ac3ac000000000000000000000000000000000000, FW:1.10
Drive H: - 693 GB / 645 GiB - CHS 42154 255 63, sector size=1024 - AMD 2+0 Stripe/RAID0, S/N:d4ea1e5ac3ac000000000000000000000000000000000000, FW:1.10
Drive U: - 104 GB / 97 GiB - CHS 6374 255 63, sector size=1024 - AMD 2+0 Stripe/RAID0, S/N:d4ea1e5ac3ac000000000000000000000000000000000000, FW:1.10
Drive V: - 314 GB / 292 GiB - CHS 19122 255 63, sector size=1024 - AMD 2+0 Stripe/RAID0, S/N:d4ea1e5ac3ac000000000000000000000000000000000000, FW:1.10
Drive Z: - 5999 GB / 5587 GiB - CHS 3128548864 1 1, sector size=512
Disk /dev/sda - 6001 GB / 5589 GiB - JMB352 RAID-0
Analyse Disk /dev/sda - 6001 GB / 5589 GiB - CHS 729602 255 63
Backup partition structure
partition_save
NTFS at 16/113/34
Warning: number of bytes per sector mismatches 2048 (NTFS) != 512 (HD)
filesystem size 370200064
sectors_per_cluster 2
mftmirr_lcn 2
clusters_per_mft_record -11
HPFS - NTFS 16 113 34 92191 254 31 1480800256 [Backup]
NTFS, blocksize=4096, 758 GB / 706 GiB
file_pread(4,2,buffer,3131131903(729602/164/34)) lseek err Invalid argument
file_pread(4,1,buffer,3131131903(729602/164/34)) lseek err Invalid argument
* HPFS - NTFS 16 113 34 92191 254 31 1480800256 [Backup]
1 * HPFS - NTFS 16 113 34 92191 254 31 1480800256 [Backup]
NTFS at 16/113/34
mftmirr_lcn 2
BAD_RS LBA=2533452001 12578014
FAT12 157700 23 53 370827 116 37 3423891099
BAD_RS LBA=3152906992 10655592
file_pread(4,1,buffer,3152906992(730958/20/55)) lseek err Invalid argument
HPFS - NTFS 730958 20 55 997169 85 20 4276683776
This partition ends after the disk limits. (start=11742841584, size=4276683776, end=16019525359, disk end=11721066304)
file_pread(4,2,buffer,3131131904(729602/164/35)) lseek err Invalid argument
file_pread(4,14,buffer,3131131906(729602/164/37)) lseek err Invalid argument
file_pread(4,3,buffer,3131131920(729602/164/51)) lseek err Invalid argument
file_pread(4,3,buffer,3131131967(729602/165/35)) lseek err Invalid argument
file_pread(4,8,buffer,3131131983(729602/165/51)) lseek err Invalid argument
file_pread(4,11,buffer,3131132030(729602/166/35)) lseek err Invalid argument
file_pread(4,2,buffer,3131133952(729602/197/4)) lseek err Invalid argument
The harddisk (6001 GB / 5589 GiB) seems too small! (< 8201 GB / 7638 GiB)
P FAT12 157700 23 53 370827 116 37 3423891099
2 P FAT12 157700 23 53 370827 116 37 3423891099
write!
Re: The harddisk seems too small
As you had 2 partitions and you have created the backup.log file where a single raw partition was listed, this file is useless.
Try EFI GPT partition table instead of PC Intel.
After Quick Search, manually add an NTFS partition starting after the first NTFS, with some luck, it will be the correct location of your VeraCrypt partition.
Set the partition as P(rimary). On next screen, choose Write, confirm, Quit and restart your computer.
If it doesn't work, try http://sourceforge.net/projects/testcrypt/
Good luck
Good luck
Thank you for your answer.
I am just giving it a try. This Quick Search seems to take a VERY long time: about 1 second per cylinder, and approx. 630000 cylinders to be read...
Best Regards
Mike
Best Regards
Mike
Quick search did finish, finally.
When I try to add a ntfs partition I have to enter a number for the size (in sectors) of the new partition. But I do not have no idea which number to enter here. Could you please help once more?
Regards
Mike
Regards
Mike
