Recover Files from Samsung Evo 840 SSD 240GB
t0511
#1 Post by t0511 »
Hello ,
I have a pretty big problem:
-The Evo 840 SSD was used for Windows to boot the PC
-One morning the Windows 10 Auto Repair started, I could not boot into Windows anymore
-I followed a guide on how to recover the data. I ran chkdsk, which created a found folder.
-I restored lots of files and junk with different tools, including testdisk and photorec
My problem is that I'm looking for a specific file (.sdf) , which is not supported by photorec
Also, photorec ran for days and was in a loop between certain sectors. As I'm looking for one important file though, maybe it would be easier, if that file type was added to photorec. I'm using the newest build.
Can someone Add .sdf files? And is it even possible to recover that file after running chkdsk?
Photorec Onlinchecker Link: https://www.cgsecurity.org/photorec/sca ... 67a490300f
Thanks in advance!
Re: Recover Files from Samsung Evo 840 SSD 240GB
Have you tried latest PhototRec 7.1-WIP ? It's faster than previous version.
Can you provide several .sdf files ? What software has created the file you uploaded ?
t0511
#3 Post by t0511 »
Hello cgrenier,
thank you for your reply. I tryed both, Photorec 7 and 7.1.
I cannot really provide any different .sdf files because I only have that one I uploaded.
The software that creates these files is called Woax-IT Easyfirma. Its a Software for creating Invoices and things like that. The .sdf file is a Backup file. I also might have had a backup in a Zip, which is a few weeks old on the desktop.
If we cant find the .sdf File, that Zip on the desktop would also work. Not ideal, but better than nothing.
t0511
#4 Post by t0511 »
Sorry for double posting, I just need to know if you have any solution for me or if you are trying to implement the .sdf format. I need to know if I should keep waiting or send it to a Data Recovery Company.
