Mov file recovery issues
lironzz
#1 Post by lironzz »
HI everyone
I have been trying vigorously to recover some files off my corrupted 16gb microsd card that i used with my olmypus tough camera.
I have successfully recovered all jpeg pictures but there should be some 80 odd mov files that I am facing difficulties with.
I am using photorec 7.1 on a windows 7 64 bit OS. When i recover them about 80 mov files come out all with names like f8804480_ftyp and they all seem to show the right file type, length of play, size etc although when played they show a black screen and white noise.When I choose to show mdat files separately in photorec then about 199 files show up but they are all named the same with names like f8804480_ftyp. They all show fairly large size files with expected time of play etc and so far i can't see any distinction in these files that could help me match them up.
I am really hoping somebody could help me out here.
Thanks!
Re: Mov file recovery issues
Try to concat the mov files as explained in https://www.cgsecurity.org/testdisk.pdf chapter "Recovering lost videos from a memory card using PhotoRec"
lironzz
#3 Post by lironzz »
Thanks for the reply, but I have read that and followed the instructions. My issue is with what happens after i recover the files and being able to distinguish them. There is no indication which files are Mdat that i can see. All files are atleast a few MB and names are the same. Although when separeted the number of files is almost tripled.
lironzz
#4 Post by lironzz »
Still having issues, was wondering if anybody has any suggestions?
Cheers
#5 Post by cgrenier »
You need to use latest 7.1-WIP, not an older version.
lironzz
#6 Post by lironzz »
Thanks for the reply again. But this is the only version that I have used and it is still not working out for me.
#7 Post by cgrenier »
You can enable the option "mov/mdat Recover mdat atom as a separate file" in FileOpts from PhotoRec 7.1-WIP and try to concat the recovered files as explained in the pdf.
haydomiata
#8 Post by haydomiata »
Im having the same issues, every video is coming with the correct length but just black screen and white noise, has anybody figured it out?
#9 Post by cgrenier »
haydomiata, did you try what I suggest previously:
cgrenier wrote: 08 Jun 2018, 05:53 You can enable the option "mov/mdat Recover mdat atom as a separate file" in FileOpts from PhotoRec 7.1-WIP and try to concat the recovered files as explained in the pdf.
