File partition recovery Topic is solved
hollinew
#1 Post by hollinew »
In the absence of any physical damage, my SanDisk Cruzer External USB drive (15.7 GB) is no longer readable. The partition system was initiated on my laptop, a MacBook Pro (13-inch, Mid 2012) running 10.13.12 High Sierra. Below is the external drive information returned from diskutil list and diskutil info /dev/disk3
 ➜ diskutil list
/dev/disk0 (internal, physical):
   #:                       TYPE NAME                    SIZE       IDENTIFIER
   0:      GUID_partition_scheme                        *750.2 GB   disk0
   1:                        EFI EFI                     209.7 MB   disk0s1
   2:          Apple_CoreStorage Macintosh HD            749.3 GB   disk0s2
   3:                 Apple_Boot Recovery HD             650.0 MB   disk0s3
/dev/disk1 (internal, virtual):
   0:                  Apple_HFS Macintosh HD           +748.9 GB   disk1
                                 Logical Volume on disk0s2
                                 C37F3541-17DE-49E6-B5BC-2B60076D62AD
                                 Unlocked Encrypted
/dev/disk3 (external, physical):
   0:     FDisk_partition_scheme                        *15.7 GB    disk3
➜ diskutil info /dev/disk3
   Device Identifier:        disk3
   Device Node:              /dev/disk3
   Whole:                    Yes
   Part of Whole:            disk3
   Device / Media Name:      Cruzer Glide
   Volume Name:              Not applicable (no file system)
   Mounted:                  Not applicable (no file system)
   File System:              None
   Content (IOContent):      FDisk_partition_scheme
   OS Can Be Installed:      No
   Media Type:               Generic
   Protocol:                 USB
   SMART Status:             Not Supported
   Disk Size:                15.7 GB (15698231296 Bytes) (exactly 30660608 512-Byte-Units)
   Device Block Size:        512 Bytes
   Read-Only Media:          No
   Read-Only Volume:         Not applicable (no file system)
   Device Location:          External
   Removable Media:          Removable
   Media Removal:            Software-Activated
   Virtual:                  No
   OS 9 Drivers:             No
   Low Level Format:         Not supported
~ took 2s
Using TestDisk, I did a deep scan, which returned the following. I have seen other posts about creating an image backup, but didn't know if this was straightforward enough of a fix to not worry about that. I also have attached my log file in full below.
 Disk /dev/disk3 - 15 GB / 14 GiB - 30660608 sectors
The harddisk (15 GB / 14 GiB) seems too small! (< 2246 GB / 2092 GiB)
>  FAT32 LBA                     38   30660613   30660576 [NO NAME]
   FAT16 >32M            1286397454 4388646105 3102248652
   FAT16 >32M            1308096031 3377048781 2068952751
When trying to recover the data before repairing the partitions, I am able to see the file names, but when I try to copy all selected files to a folder I created on my internal drive, only the commercial SanDisk "quick start" folder is transferred. Is this because those files are housed within the deleted partitions while the SanDisk is in the initial FAT32 LBA? Would transferring these files to a separate external hard drive, rather than an internal drive, amend this issue?
It is my impression that if I can recover the partitions than there is no longer a need for data recovery, so this additional problem I think can be disregarded if the partitions are salvageable.
Please let me know any suggestions and thank you tremendously in advance for any guidance you can provide.
EDIT: Here is correct original log file with the indicated Intel.
Sat Apr  7 18:11:38 2018
TestDisk 7.1-WIP, Data Recovery Utility, March 2018
OS: Darwin, kernel 17.3.0 (Darwin Kernel Version 17.3.0: Thu Nov  9 18:09:22 PST 2017; root:xnu-4570.31.3~1/RELEASE_X86_64) x86_64
Compiler: GCC 4.0
Compilation date: 2018-03-19T20:41:07
Disk /dev/disk2 - 15 GB / 14 GiB - 30660608 sectors, sector size=512
Disk /dev/disk3 - 15 GB / 14 GiB - 30660608 sectors, sector size=512
Disk /dev/rdisk2 - 15 GB / 14 GiB - 30660608 sectors, sector size=512
Disk /dev/rdisk3 - 15 GB / 14 GiB - 30660608 sectors, sector size=512
Partition table type: None
   P Unknown                        0   30660607   30660608
Analyse Disk /dev/disk3 - 15 GB / 14 GiB - 30660608 sectors
BAD_RS LBA=1 1339
check_part_i386 failed for partition type AF
get_geometry_from_list_part_aux head=1 nbr=2
No HFS or HFS+ structure
 1 * HFS                            1   30660576   30660576
FAT32 at 32/0/1
FAT1 : 12-7493
FAT2 : 7494-14975
start_rootdir : 14976 root cluster : 2
Data : 14976-30660575
sectors : 30660576
cluster_size : 32
no_of_cluster : 957675 (2 - 957676)
fat_length 7482 calculated 7482
heads/cylinder 255 (FAT) != 1 (HD)
sect/track 63 (FAT) != 1 (HD)
FAT32 at 32/0/1
FAT: cluster=2(0x2), pos=15008
FAT: cluster=53610(0xd16a), pos=1730464
FAT: cluster=190903(0x2e9b7), pos=6123840
FAT: cluster=47031(0xb7b7), pos=1519936
FAT: cluster=204545(0x31f01), pos=6560384
     FAT32 LBA                     32   30660607   30660576 [EWH]
     FAT32, blocksize=16384, 15 GB / 14 GiB
Warning: the current number of heads per cylinder is 1 but the correct value may be 32.
   * FAT32 LBA                     32   30660607   30660576 [EWH]
 1 * FAT32 LBA                     32   30660607   30660576 [EWH]
BAD_RS LBA=1 1339
FAT32 at 32/0/1
FAT1 : 12-7493
FAT2 : 7494-14975
sectors : 30660576
cluster_size : 32
FAT32 at 32/0/1
BAD_RS LBA=1 1339
New options :
 Dump : No
 Align partition: Yes
 Expert mode : No
BAD_RS LBA=1 1339
r-xr-x     0      0         0 29-Nov-2017 16:06 11-29-2017 AHR Quantifications
X 263337 -rwxr-xr-x     0      0       450 29-Nov-2017 16:07 DATA (D) - Shortcut.lnk
X 263343 drwxr-xr-x     0      0         0  9-Dec-2017 13:18 New folder
X 263343 drwxr-xr-x     0      0         0  9-Dec-2017 13:18 12-9-17 Confocal
X      0 -rwxr-xr-x     0      0         0 21-Dec-2017 06:49 12-20-17 STAT1_Keystone_Abstract.docx
X 524381 -rwxr-xr-x     0      0     19798 21-Dec-2017 06:49 _WRD0000.TMP
  524381 -rwxr-xr-x     0      0     19798 21-Dec-2017 06:49 12-20-17 STAT1_Keystone_Abstract.docx
X 541708 -rwxr-xr-x     0      0    236821  2-Feb-2018 13:32 _WRD1000.TMP
X  47318 -rwxr-xr-x     0      0    196237  2-Feb-2018 07:03 _WRL1203.TMP
X 541708 -rwxr-xr-x     0      0    236821  2-Feb-2018 13:32 2018-AHR 1312018  draft 1 ethan.docx
X 524389 drwxr-xr-x     0      0         0  4-Feb-2018 16:53 New folder
  524389 drwxr-xr-x     0      0         0  4-Feb-2018 16:53 2-4-18 Confocal
X 262238 drwxr-xr-x     0      0         0 13-Feb-2018 11:03 New folder
  262238 drwxr-xr-x     0      0         0 13-Feb-2018 11:03 2-13-2018 Confocal
X 262241 drwxr-xr-x     0      0         0 16-Feb-2018 10:59 New folder
  262241 drwxr-xr-x     0      0         0 16-Feb-2018 10:59 2-16-2018 Confocal
  263320 drwxr-xr-x     0      0         0  5-Mar-2018 13:33 3-5-18 IFNg
X 524396 drwxr-xr-x     0      0         0  6-Mar-2018 15:50 New folder
  524396 drwxr-xr-x     0      0         0  6-Mar-2018 15:50 3-6-18 Confocal
  656318 -rwxr-xr-x     0      0     57168  8-Mar-2018 16:15 Gresham_LOR.PDF
X 656322 drwxr-xr-x     0      0         0 12-Mar-2018 15:36 New folder
X 656323 drwxr-xr-x     0      0         0 12-Mar-2018 15:36 New folder (2)
X 656323 drwxr-xr-x     0      0         0 12-Mar-2018 15:36 _
  656323 drwxr-xr-x     0      0         0 12-Mar-2018 15:36 3-12-18 IFNg
X 593362 drwxr-xr-x     0      0         0 19-Mar-2018 11:44 New folder (2)
  593362 drwxr-xr-x     0      0         0 19-Mar-2018 11:44 3-19-18 IFNg
X 263322 drwxr-xr-x     0      0         0 20-Mar-2018 13:04 New folder
  263322 drwxr-xr-x     0      0         0 20-Mar-2018 13:04 3-20-18 Confocal
BAD_RS LBA=1 1339
FAT32 at 32/0/1
FAT1 : 12-7493
FAT2 : 7494-14975
sectors : 30660576
cluster_size : 32
FAT32 at 32/0/1
FAT32 at 32/0/1
FAT1 : 12-7493
FAT2 : 7494-14975
sectors : 30660576
cluster_size : 32
FAT32 at 32/0/1
FAT32 at 38/0/1
FAT1 : 12-7493
FAT2 : 7494-14975
sectors : 30660576
cluster_size : 32
FAT32 at 38/0/1
FAT: cluster=2(0x2), pos=15014
FAT: cluster=771(0x303), pos=39622
FAT: cluster=1540(0x604), pos=64230
FAT: cluster=2309(0x905), pos=88838
FAT: cluster=3078(0xc06), pos=113446
FAT: cluster=3847(0xf07), pos=138054
FAT: cluster=4616(0x1208), pos=162662
FAT: cluster=5385(0x1509), pos=187270
FAT: cluster=6154(0x180a), pos=211878
FAT: cluster=6923(0x1b0b), pos=236486
FAT: cluster=7692(0x1e0c), pos=261094
FAT: cluster=8461(0x210d), pos=285702
FAT: cluster=9230(0x240e), pos=310310
FAT: cluster=9999(0x270f), pos=334918
FAT: cluster=10768(0x2a10), pos=359526
FAT: cluster=11537(0x2d11), pos=384134
FAT: cluster=12306(0x3012), pos=408742
FAT: cluster=13075(0x3313), pos=433350
FAT: cluster=13844(0x3614), pos=457958
FAT: cluster=14613(0x3915), pos=482566
FAT: cluster=15382(0x3c16), pos=507174
FAT: cluster=16151(0x3f17), pos=531782
FAT: cluster=16920(0x4218), pos=556390
FAT: cluster=17689(0x4519), pos=580998
FAT: cluster=18458(0x481a), pos=605606
FAT: cluster=19227(0x4b1b), pos=630214
FAT: cluster=19996(0x4e1c), pos=654822
FAT: cluster=20765(0x511d), pos=679430
FAT: cluster=21534(0x541e), pos=704038
FAT: cluster=22303(0x571f), pos=728646
FAT: cluster=23072(0x5a20), pos=753254
FAT: cluster=23841(0x5d21), pos=777862
FAT: cluster=24610(0x6022), pos=802470
FAT: cluster=25379(0x6323), pos=827078
FAT: cluster=26148(0x6624), pos=851686
FAT: cluster=26917(0x6925), pos=876294
FAT: cluster=27686(0x6c26), pos=900902
FAT: cluster=28455(0x6f27), pos=925510
FAT: cluster=29224(0x7228), pos=950118
FAT: cluster=29993(0x7529), pos=974726
FAT: cluster=30762(0x782a), pos=999334
FAT: cluster=31531(0x7b2b), pos=1023942
FAT: cluster=32300(0x7e2c), pos=1048550
FAT: cluster=33069(0x812d), pos=1073158
FAT: cluster=33838(0x842e), pos=1097766
FAT: cluster=34607(0x872f), pos=1122374
FAT: cluster=35376(0x8a30), pos=1146982
FAT: cluster=36145(0x8d31), pos=1171590
FAT: cluster=36914(0x9032), pos=1196198
FAT: cluster=37683(0x9333), pos=1220806
FAT: cluster=38452(0x9634), pos=1245414
This partition ends after the disk limits. (start=38, size=30660576, end=30660613, disk end=30660608)
BAD_RS LBA=1286397454 277
This partition ends after the disk limits. (start=1286397454, size=3102248652, end=4388646105, disk end=30660608)
BAD_RS LBA=1308096031 907
This partition ends after the disk limits. (start=1308096031, size=2068952751, end=3377048781, disk end=30660608)
BAD_RS LBA=1 1339
BAD_RS LBA=1 1339
BAD_RS LBA=1 1339
BAD_RS LBA=1 1339
Re: File partition recovery
Use PC Intel partition table type, not "None".
hollinew
#3 Post by hollinew »
@cgrenier
Below is correct log file with Intel table type run.
Compiler: GCC 4.0
BAD_RS LBA=1 1339
FAT32 at 32/0/1
FAT1 : 12-7493
FAT2 : 7494-14975
sectors : 30660576
cluster_size : 32
FAT32 at 32/0/1
BAD_RS LBA=1 1339
FAT32 at 32/0/1
FAT1 : 12-7493
FAT2 : 7494-14975
sectors : 30660576
cluster_size : 32
FAT32 at 32/0/1
BAD_RS LBA=1 1339
New options :
 Dump : No
 Expert mode : No
BAD_RS LBA=1 1339
BAD_RS LBA=1 1339
FAT32 at 32/0/1
FAT1 : 12-7493
FAT2 : 7494-14975
sectors : 30660576
cluster_size : 32
FAT32 at 32/0/1
FAT32 at 32/0/1
FAT1 : 12-7493
FAT2 : 7494-14975
sectors : 30660576
cluster_size : 32
FAT32 at 32/0/1
FAT32 at 38/0/1
FAT1 : 12-7493
FAT2 : 7494-14975
sectors : 30660576
cluster_size : 32
FAT32 at 38/0/1
BAD_RS LBA=1 1339
BAD_RS LBA=1 1339
BAD_RS LBA=1 1339
BAD_RS LBA=1 1339
hollinew
#4 Post by hollinew »
@cgrenier
Compiler: GCC 4.0
BAD_RS LBA=1 1339
FAT32 at 32/0/1
FAT1 : 12-7493
FAT2 : 7494-14975
sectors : 30660576
cluster_size : 32
FAT32 at 32/0/1
BAD_RS LBA=1 1339
FAT32 at 32/0/1
FAT1 : 12-7493
FAT2 : 7494-14975
sectors : 30660576
cluster_size : 32
FAT32 at 32/0/1
BAD_RS LBA=1 1339
New options :
 Dump : No
 Expert mode : No
BAD_RS LBA=1 1339
BAD_RS LBA=1 1339
FAT32 at 32/0/1
FAT1 : 12-7493
FAT2 : 7494-14975
sectors : 30660576
cluster_size : 32
FAT32 at 32/0/1
FAT32 at 32/0/1
FAT1 : 12-7493
FAT2 : 7494-14975
sectors : 30660576
cluster_size : 32
FAT32 at 32/0/1
FAT32 at 38/0/1
FAT1 : 12-7493
FAT2 : 7494-14975
sectors : 30660576
cluster_size : 32
FAT32 at 38/0/1
BAD_RS LBA=1 1339
BAD_RS LBA=1 1339
BAD_RS LBA=1 1339
BAD_RS LBA=1 1339
