Recover of disappeared FAT32 partition content
bruce
#1 Post by bruce »
Hello testdisk community,
after a move and an enlargement of one particular partition on a 2 TB HDD, this disk could not be started.
Fortunately I use a multiboot grub system and carried out testdisk with an old win xp system.
After several passes of analysis the MFT was replaced and a new MBR was written to disk.
The result was that the HDD would again not start.
Most of the partitions are available and visible. Except for one with a size of about 104 GiB.
According the testdisk recovery examples at https://www.cgsecurity.org/wiki/TestDisk_Step_By_Step
After several passes of testdisk
[Analyse] --> [Quick Search] --> [Deeper Search]
Sat Apr  7 22:05:43 2018
OS: Windows XP SP2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=400088457216
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=400088457216
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=31560367104
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=214030139904
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=107602887168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=31876637184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=100162331136
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=33846994944
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=64469647872
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=52169015808
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\N:)=32218389504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\O:)=164508664320
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\P:)=32226614784
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Q:)=42796099584
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\R:)=10768310784
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\S:)=152191517184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\T:)=60620087808
filewin32_getfilesize(\\.\U:) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\U:) SetFilePointer err Unzulässige Funktion.
Warning: can't get size for \\.\U:
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\V:)=160338092544
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\W:)=52169015808
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\X:)=64776208896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Y:)=54192112128
Disk /dev/sda - 400 GB / 372 GiB - CHS 48641 255 63, sector size=512
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 3876021 16 63, sector size=512
Drive C: - 31 GB / 29 GiB - CHS 3836 255 63, sector size=512
Drive E: - 214 GB / 199 GiB - CHS 414709 16 63, sector size=512
Drive F: - 107 GB / 100 GiB - CHS 208493 16 63, sector size=512
Drive H: - 31 GB / 29 GiB - CHS 61764 16 63, sector size=512
Drive I: - 100 GB / 93 GiB - CHS 194076 16 63, sector size=512
Drive J: - 33 GB / 31 GiB - CHS 4114 255 63, sector size=512
Drive L: - 64 GB / 60 GiB - CHS 124917 16 63, sector size=512
Drive M: - 52 GB / 48 GiB - CHS 101083 16 63, sector size=512
Drive N: - 32 GB / 30 GiB - CHS 3916 255 63, sector size=512
Drive O: - 164 GB / 153 GiB - CHS 318755 16 63, sector size=512
Drive P: - 32 GB / 30 GiB - CHS 3917 255 63, sector size=512
Drive Q: - 42 GB / 39 GiB - CHS 5202 255 63, sector size=512
Drive R: - 10 GB / 10 GiB - CHS 20864 16 63, sector size=512
Drive S: - 152 GB / 141 GiB - CHS 294889 16 63, sector size=512
Drive T: - 60 GB / 56 GiB - CHS 117458 16 63, sector size=512
Drive V: - 160 GB / 149 GiB - CHS 310674 16 63, sector size=512
Drive X: - 64 GB / 60 GiB - CHS 125511 16 63, sector size=512
Drive Y: - 54 GB / 50 GiB - CHS 105003 16 63, sector size=512
Analyse Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 3876021 16 63
Geometry from i386 MBR: head=16 sector=63
NTFS at 0/1/1
FAT32 at 231306/1/1
Info: size boot_sector 118398609, partition 118398609
FAT1 : 32-28947
FAT2 : 28948-57863
start_rootdir : 2396424 root cluster : 73082
Data : 57864-118398599
sectors : 118398609
cluster_size : 32
no_of_cluster : 3698148 (2 - 3698149)
fat_length 28916 calculated 28892
NTFS at 348765/1/1
FAT32 at 473683/1/1
Info: size boot_sector 163024785, partition 163024785
FAT1 : 32-39835
FAT2 : 39836-79639
start_rootdir : 118390520 root cluster : 3697217
Data : 79640-163024759
sectors : 163024785
cluster_size : 32
no_of_cluster : 5092035 (2 - 5092036)
fat_length 39804 calculated 39782
NTFS at 817512/1/1
NTFS at 1136268/1/1
NTFS at 1431158/1/1
FAT32 at 1845868/1/1
Info: size boot_sector 50181201, partition 50181201
FAT1 : 32-24538
FAT2 : 24539-49045
start_rootdir : 1190582 root cluster : 71348
Data : 49046-50181189
sectors : 50181201
cluster_size : 16
no_of_cluster : 3133259 (2 - 3133260)
fat_length 24507 calculated 24479
FAT32 at 1895651/1/1
Info: size boot_sector 62259057, partition 62259057
FAT1 : 32-15231
FAT2 : 15232-30431
start_rootdir : 1700896 root cluster : 52204
Data : 30432-62259039
sectors : 62259057
cluster_size : 32
no_of_cluster : 1944644 (2 - 1944645)
fat_length 15200 calculated 15193
FAT32 at 1957416/1/1
Info: size boot_sector 21031857, partition 21031857
FAT1 : 33-10302
FAT2 : 10303-20572
start_rootdir : 309325 root cluster : 18049
Data : 20573-21031852
sectors : 21031857
cluster_size : 16
no_of_cluster : 1313205 (2 - 1313206)
fat_length 10270 calculated 10260
FAT32 at 1978281/1/1
Info: size boot_sector 313160337, partition 313160337
FAT1 : 32-76491
FAT2 : 76492-152951
start_rootdir : 3981912 root cluster : 119657
Data : 152952-313160311
sectors : 313160337
cluster_size : 32
no_of_cluster : 9781480 (2 - 9781481)
fat_length 76460 calculated 76418
FAT32 at 2288956/1/1
Info: size boot_sector 101892609, partition 101892609
FAT1 : 33-24910
FAT2 : 24911-49788
start_rootdir : 329021 root cluster : 8728
Data : 49789-101892604
sectors : 101892609
cluster_size : 32
no_of_cluster : 3182588 (2 - 3182589)
fat_length 24878 calculated 24864
FAT32 at 2390040/1/1
Info: size boot_sector 85675905, partition 85675905
FAT1 : 32-20955
FAT2 : 20956-41879
start_rootdir : 588504 root cluster : 17084
Data : 41880-85675895
sectors : 85675905
cluster_size : 32
no_of_cluster : 2676063 (2 - 2676064)
fat_length 20924 calculated 20907
NTFS at 2475036/1/1
Info: size boot_sector 105843968, partition 105843969
FAT32 at 2580040/1/1
Info: size boot_sector 195629553, partition 195629553
FAT1 : 32-47803
FAT2 : 47804-95575
start_rootdir : 163024760 root cluster : 5091539
Data : 95576-195629527
sectors : 195629553
cluster_size : 32
no_of_cluster : 6110436 (2 - 6110437)
fat_length 47772 calculated 47738
FAT32 at 2774117/1/1
FAT1 : 33-24910
FAT2 : 24911-49788
sectors : 101892609
cluster_size : 32
FAT32 at 2875201/1/1
Info: size boot_sector 126515373, partition 126516033
FAT1 : 32-30923
FAT2 : 30924-61815
start_rootdir : 588504 root cluster : 16461
Data : 61816-126515351
sectors : 126515373
cluster_size : 32
no_of_cluster : 3951673 (2 - 3951674)
fat_length 30892 calculated 30873
get_geometry_from_list_part_aux head=16 nbr=66
get_geometry_from_list_part_aux head=8 nbr=66
get_geometry_from_list_part_aux head=32 nbr=34
get_geometry_from_list_part_aux head=64 nbr=25
get_geometry_from_list_part_aux head=128 nbr=9
get_geometry_from_list_part_aux head=240 nbr=5
 1 * HPFS - NTFS              0   1  1 208493  15 63  210161889
 2 E extended LBA         231306   0  1 3000712  15 63 2791562256
 5 L FAT32 LBA            231306   1  1 348764  15 63  118398609 [NO NAME]
   X extended             348765   0  1 473682  15 63  125917344
 6 L HPFS - NTFS          348765   1  1 473682  15 63  125917281
   X extended             473683   0  1 635413  15 63  163024848
 7 L FAT32 LBA            473683   1  1 635413  15 63  163024785 [NO NAME]
   X extended             817512   0  1 1136267  15 63  321306048
 8 L HPFS - NTFS          817512   1  1 1136267  15 63  321305985
   X extended             1136268   0  1 1431157  15 63  297249120
 9 L HPFS - NTFS          1136268   1  1 1431157  15 63  297249057
   X extended             1431158   0  1 1845867  15 63  418027680
10 L HPFS - NTFS          1431158   1  1 1845867  15 63  418027617
   X extended             1845868   0  1 1895650  15 63   50181264
11 L FAT32 LBA            1845868   1  1 1895650  15 63   50181201 [NO NAME]
   X extended             1895651   0  1 1957415  15 63   62259120
12 L FAT32 LBA            1895651   1  1 1957415  15 63   62259057 [NO NAME]
   X extended             1957416   0  1 1978280  15 63   21031920
13 L FAT32 LBA            1957416   1  1 1978280  15 63   21031857 [NO NAME]
   X extended             1978281   0  1 2288955  15 63  313160400
14 L FAT32 LBA            1978281   1  1 2288955  15 63  313160337 [FOTOS]
   X extended             2288956   0  1 2390039  15 63  101892672
15 L FAT32 LBA            2288956   1  1 2390039  15 63  101892609 [NO NAME]
   X extended             2390040   0  1 2475035  15 63   85675968
16 L FAT32 LBA            2390040   1  1 2475035  15 63   85675905 [NO NAME]
   X extended             2475036   0  1 2580039  15 63  105844032
17 L HPFS - NTFS          2475036   1  1 2580039  15 63  105843969
   X extended             2580040   0  1 2774116  15 63  195629616
18 L FAT32 LBA            2580040   1  1 2774116  15 63  195629553 [NO NAME]
   X extended             2774117   0  1 2875200  15 63  101892672
19 L FAT32 LBA            2774117   1  1 2875200  15 63  101892609 [NO NAME]
   X extended             2875201   0  1 3000712  15 63  126516096
20 L FAT32 LBA            2875201   1  1 3000712  15 63  126516033 [NO NAME]
After several passes the following testdisk messages are observed:
     NTFS, blocksize=4096, 107 GB / 100 GiB
     FAT32, blocksize=16384, 60 GB / 56 GiB
     FAT32 LBA            270503   1  1 348764  15 63   78888033 [NO NAME]
     FAT32, blocksize=16384, 40 GB / 37 GiB
     NTFS, blocksize=4096, 64 GB / 60 GiB
     FAT32, blocksize=16384, 83 GB / 77 GiB
     FAT32 LBA            599089   1  1 817511  15 63  220170321 [NO NAME]
     FAT32, blocksize=16384, 112 GB / 104 GiB
     FAT32 LBA            700789   0  8 1804279   3 42 1112318144
     NTFS, blocksize=4096, 164 GB / 153 GiB
     NTFS, blocksize=4096, 152 GB / 141 GiB
     NTFS, blocksize=4096, 214 GB / 199 GiB
     FAT32, blocksize=8192, 25 GB / 23 GiB
     FAT32, blocksize=16384, 31 GB / 29 GiB
     FAT32, blocksize=8192, 10 GB / 10 GiB
     FAT32, blocksize=16384, 160 GB / 149 GiB
     FAT32, blocksize=16384, 52 GB / 48 GiB
     FAT32, blocksize=16384, 43 GB / 40 GiB
     HPFS - NTFS          2475036   1  1 2496358  15 63   21493521
     NTFS found using backup sector, blocksize=4096, 11 GB / 10 GiB
     NTFS, blocksize=4096, 54 GB / 50 GiB
     FAT32, blocksize=16384, 100 GB / 93 GiB
     FAT32 LBA            2719242   0  8 3822732   3 42 1112318144
     FAT32, blocksize=16384, 64 GB / 60 GiB
So finally the file content of the relevant partition could be found at:
At first sight the complete directories and probably all files in the FAT32 partition can be listed. :roll:
But if I continue with testdisk, the partition will be no more indicated:
 2 E extended LBA         348765   0  1 2475035  15 63 2143281168
 5 L HPFS - NTFS          348765   1  1 473682  15 63  125917281
 6 L FAT32 LBA            1845868   1  1 1895650  15 63   50181201 [NO NAME]
 7 L FAT32 LBA            1895651   1  1 1957415  15 63   62259057 [NO NAME]
 8 L FAT32 LBA            1957416   1  1 1978280  15 63   21031857 [NO NAME]
 9 L FAT32 LBA            1978281   1  1 2288955  15 63  313160337 [FOTOS]
10 L FAT32 LBA            2288956   1  1 2390039  15 63  101892609 [NO NAME]
11 L FAT32 LBA            2390040   1  1 2475035  15 63   85675905 [NO NAME]
Because of the high quantity of files in sub-folders now the question is what to do now?
It would be a megatask for weeks rescuing file by file of the partition to another partition.
Has anyone an idea how to carry out the data rescue? :idea: :idea:
For example could ddrescue present an option to copy the relevant sectors at acceptable efforts to generate an image of the partition?
Start ........... End
Any help for support would be very kind and great.
Re: Recover of disappeared FAT32 partition content
You can use testdisk to copy several directories, no need to select the file or directory one at the time.
bruce
#3 Post by bruce »
@cgrenier
Thank you so much for your hint to follow consequently the program instructions.
finally it seems that I could recover most of the folders and files together with original filenames, dates.
The result was:
copy done! 213177 ok, 213 failed
Hallelujah!!!!!!!!!!!
Without your support I would never have reached the recovery. :-)
Sans votre soutien, je n'aurais jamais atteint le rétablissement.
Encore merci beaucoup pour votre aide.
