Unable to Recover Partition
Veee
#1 Post by Veee »
I was trying to delete an old partition on my secondary hard drive(used to have windows 7 on it) System Reserved of 100MB but instead deleted the volume. The whole drive became unallocated and the photos, videos, and programs I had on the second partition were gone. I tried running testdisk to recover the partitions however even though it detected both partitions after a quick search. Testdisk had the second partition listed as "the following partitions can't be recovered". I wrote the first partition because they didn't intersect hoping to solve my problem and ran quick search again. It still wouldn't let me recover the partition. It also says the size is too small which I think is the problem. I ran photorec for a few minutes to see if it could pull photos from it and alas it did. I at least have a backup plan in case it doesn't work out but I would still like to recover the partition nonetheless. I am currently running a deep search but below is the log from the quick search and write. I am running windows 10 on the SSD where I am running test disk on.
Wed Apr 11 00:09:54 2018
TestDisk 7.1-WIP, Data Recovery Utility, March 2018
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=209986061312
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=104857600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=104857600
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung SSD 840 EVO 250GB, S/N:xxxxxxxxxxxxxxx, FW:EXT0DB6Q
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD1002FAEX-00Z3A0, S/N:xxxxxxxxxxxxxxxx, FW:05.01D05
Disk /dev/sdb - 1000 GB / 931 GiB - WDC WD1002FAEX-00Z3A0
Geometry from i386 MBR: head=224 sector=19
NTFS at 0/32/33
 1 * HPFS - NTFS              0  32 33    12 223 19     204800 [System Reserved]
NTFS at 0/32/33
NTFS at 0/32/33
filesystem size           204800
sectors_per_cluster       8
mft_lcn                   8533
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS at 12/223/20
filesystem size           1953517568
mftmirr_lcn               2
     HPFS - NTFS             12 223 20 121613 183 42 1953517568
This partition ends after the disk limits. (start=206848, size=1953517568, end=1953724415, disk end=1953525168)
file_pread(5,2,buffer,1953525759(121601/90/25)) lseek err Invalid argument
The harddisk (1000 GB / 931 GiB) seems too small! (< 1000 GB / 931 GiB)
Re: Unable to Recover Partition
Run TestDisk. In Geometry, set the number of cylinders to 121614, Analyze, Quick Search. If both partition are listed, set the first as D(eleted), the second as P(rimary).
On next screen, choose Write, confirm, Quit and restart your computer.
You should be able to access your data.
Note that the partition is too big for the disk. After a backup, try to resize the partition using gparted or a similar disk utility.
