Recovery of HFS-formatted Western Digital Harddisk recognized as RAW
lsgit
#1 Post by lsgit »
I have a 1TB Western Digital disk, with a HFS-Partition, which is shown as a RAW disk in Windows.
The Log file shows the following:
TestDisk 7.1-WIP, Data Recovery Utility, March 2018
OS: Darwin, kernel 17.4.0 (Darwin Kernel Version 17.4.0: Sun Dec 17 09:19:54 PST 2017; root:xnu-4570.41.2~1/RELEASE_X86_64) x86_64
Compiler: GCC 4.0
Compilation date: Mar 19 201820:41:07
Disk /dev/disk2 - 1000 GB / 931 GiB - 1953458176 sectors, sector size=512
Disk /dev/rdisk2 - 1000 GB / 931 GiB - 1953458176 sectors, sector size=512
Analyse Disk /dev/rdisk2 - 1000 GB / 931 GiB - 1953458176 sectors
BAD_RS LBA=2 1339
check_part_i386 failed for partition type AF
get_geometry_from_list_part_aux head=1 nbr=2
No HFS or HFS+ structure
1 P HFS                            2 1953458175 1953458174
BAD_RS LBA=3817705145 75
     FAT32 LBA             3817705145 8020123056 4202417912
This partition ends after the disk limits. (start=3817705145, size=4202417912, end=8020123056, disk end=1953458176)
BAD_RS LBA=525044350 1130
     FAT16 <32M             525044350 2585855897 2060811548
This partition ends after the disk limits. (start=525044350, size=2060811548, end=2585855897, disk end=1953458176)
BAD_RS LBA=111049470 759
     FAT12                  111049470 4215485328 4104435859
This partition ends after the disk limits. (start=111049470, size=4104435859, end=4215485328, disk end=1953458176)
BAD_RS LBA=503899722 711
     HPFS - NTFS            503899722 2544328891 2040429170
This partition ends after the disk limits. (start=503899722, size=2040429170, end=2544328891, disk end=1953458176)
BAD_RS LBA=1973015633 728
     HPFS - NTFS           1973015633 5374370701 3401355069
This partition ends after the disk limits. (start=1973015633, size=3401355069, end=5374370701, disk end=1953458176)
BAD_RS LBA=1048164684 339
     FAT32                 1048164684 1822544159  774379476
The harddisk (1000 GB / 931 GiB) seems too small! (< 4106 GB / 3824 GiB)
   * FAT32                 1048164684 1822544159  774379476
1 * FAT32                 1048164684 1822544159  774379476
BAD_RS LBA=2 1339
Do do not understand, why it is showing me FAT & NTFS Partitions, which ca not be recovered. Are those old ones from the time before the disk was formatted under MacOS?
As you can see the logfile, would it be possible to "repair" my disk?
Regards
lsgit
Re: Recovery of HFS-formatted Western Digital Harddisk recognized as RAW
There is a chapter about repairing filesystem in https://www.cgsecurity.org/testdisk.pdf PhotoRec can used if it doesn't work.
Note that
- Windows can not access HFS or HFS+ partition.
- HFS partition aren't used for harddisk, only HFS+.
