How to recover partition?
belladaisy2018
#1 Post by belladaisy2018 »
Hi All:
I have an Edge SSD 128 GB disk that I can't format. Testdisk shows no partition and does not find any backup to recover.
Any help will be greatly appreciated. Thanks
Analysis File:
Sat Feb 22 14:19:33 2014
TestDisk 7.0-WIP, Data Recovery Utility, January 2014
Compilation date: 2014-02-02T16:29:31
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=128035675648
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=128035675648
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=312090950144
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - WDC WD32 00BEKT-60V5T, S/N:W -DXW1H3AX07657, FW:12.0
Disk /dev/sdb - 128 GB / 119 GiB - CHS 15566 255 63, sector size=512 - EDGE SSD
Disk /dev/sdb - 128 GB / 119 GiB - EDGE SSD
Analyse Disk /dev/sdb - 128 GB / 119 GiB - CHS 15566 255 63
test_FAT()
1 P FAT16 >32M 0 32 33 15565 241 36 250064896
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
Invalid FAT boot sector
Re: How to recover partition?
The output of testdisk, Analyze, Quick Search and Deepr Search would have been useful...
You wrote that you tried to format your disk. It means you don't care about the data. If you failed to format the disk, get a new disk, use the warranty if possible.
If you want to recover some data, try PhotoRec.
