Write error: Can't overwrite NTFS backup boot sector
RhysD
#1 Post by RhysD »
Hi all,
My external hard drive now takes very long to copy single files, often spending 5 minutes calculating the size of a tiny file before not even copying it. Large files or directories just doesnt work at all. I can see the files - but just loading a dir in windows takes a while.
So i ran TestDisk and choose the Boot menu ->
Drive E: - 1000 GB / 931 GiB - CHS 121597 255 63
P NTFS 0 0 1 121597 5 8 1953456128 [My Passport]
Boot sector Status: OK
Backup boot sector ntfs_boot_sector: Can't read backup boot sector.
Status: Bad
Sectors are not identical.
The attachment Capture.PNG is no longer available
I choose Org.BS - copy boot sector over backup sector ->
The attachment Capture3.PNG is no longer available
Is the unreadable backup boot sector the issue and if so any ideas how to fix? If not any further ideas?
Re: Write error: Can't overwrite NTFS backup boot sector
Your disk slowdown is probably due to bad sectors.
You should clone your disk to a new empty one using ddrescue as described in https://www.cgsecurity.org/testdisk.pdf
Once it's done, remove the original disk and try to access your data on the clone.
RhysD
#3 Post by RhysD »
Many thanks. I will have a go at this and feedback!
